mikes2017gt
- Feb 21, 2017
- San Antonio, TX
- 17 GT Prem M/T 3.55
This thread will detail the swap/installation of Brembo 6-pot calipers and PowerStop rotors on my '17 GT Premium, non-PP. This will not be a "done in two days" install, so please stay tuned. I have all the parts; it's the TIME to do the work that is in short supply.
I did a ton of research and asked a lot of questions before undertaking this swap. I'm confident it will turn out well. Like many other folks, the first thing I looked at was the FP PP front brake kit. Basically, $1.2K for the 6-pot Brembos, stock rotors and PP pads, clips and splash shields. For just under that amount, I got all that and added drilled/slotted rotors for front and rear, better pads, stainless lines and the power bleeder. I think I did pretty well.
The biggest question I had was "Will the Brembos fit inside the optional 20" Foundry wheels? Found at least one thread here with pics that showed that they do. Also, general online consensus is that the majority of 20" wheels fit over 6-pot Brembos. I went with that positive vibe.
I will detail all part numbers in a future post, but for tonight here's the quick overview:
50th Anniversary Brembos (6-pot, white letters...matches my car)
Pad clip/pin kit for the GT-PP (fits 15" rotors)
New caliper bolts (b/c cheap insurance for $5, that's why)
PowerStop drilled/slotted rotors front and rear, sized for the PP (BrakeMotive F/R set off EBay)
PowerStop Z26 pads F/R
Steeda stainless brake lines
New banjo bolts/crush washers
32oz of Motorcraft DOT4 brake fluid
Motorcraft anti-seize compound for pins/backs of pads
Motive PowerBleeder with #1100 reservoir adaptor
Some cheapo random catch bottle I bought for $5 to catch the bleedout from the calipers
Here's a little eye candy.
They are just beautiful.
Got the splash shields and clips/pins for the pads.
My....my preciousssssssssssss
I should be able to do the swap this weekend. That's the plan. The very first thing I will do is remove one front wheel. Remove the stock caliper and rotor. Put new rotor on. Loosely bolt Brembo in place. Put on wheel and attempt to turn it. That, obviously, is the deal-breaker point, and what I'm seriously Jonesing to see with my own eyes. 1/8" of clearance is not the same thing as 1/32" of clearance. I need to see and measure. Stay tuned!
