Please Help - Brake stuck when starting my mustang 2015
mustang3055
miami
mike
mustang
Had this bad boy for 4 years and never given me serious problems,
Last night I when I got in my car the break pedal was hard to the point where I could not press it down to press the start button, since the break pedal was stuck the only thing the car could do is start the battery but the not actual engine
That has never happened to me before, eventually I tried to start the car using the remote start with the key fob and the car turned on fine
Once on the car was on the breaks worked fine and no weird lights came up in the light box, I thought it was just a one time occurance but this morning it happened again!!
The break is stuck on start but the car turns on using the remote start with the key
It also seems to only happened when the car is off for more than 1 hour
Has anyone ever experienced something like this? Any idea how to fix it or how much it will cost to fix on the dealership
NoVaGT
Northern Virginia
2019 PP1 GT Kona
Last night I when I got in my car the break was hard to the point where I could not press it down to press the start button, since the break was stuck the only thing the car could do is start the battery but the not actual engine
Are you trying to say the brake pedal was stuck?
SoulHunter91
2020 Mustang Twister Orange
I believe that’s normal. When the car is off, sometimes you cannot fully depress brake pedal all the way down and it feels like it stucks. But If you hit start button, it should still start the engine and brake pedal now can be depressed all the way.
Bikeman315
Myrtle Beach, SC
Ira
Check the brake switch. If it is disconnected or broken the car will not start.
SoulHunter91
Brake switch? Where is it located? I don’t have problem with starting the car, the brake pedal cannot fully be depressed as OP describes
AceS550
Houston,TX
Ace
2019 Bullitt
Sounds like a leaking brake booster check valve or leaking brake booster.
Vacuum in the system is supposed to be held for emergency braking in the event that the engine stalls. The system should normally hold vacuum overnight.
I would get it looked at immediately.
gamecoc430
South Carolina
2017 Mustang GT Premium
I had the same problem for three years. I, and the dealer, tried everything including all suggestions above. Finally opened a ticket with Ford, their solution was to replace the entire brake pedal assembly. Guess what? Has never done it again in several months. It used to do it several times a week. Good luck!
gamecoc430
South Carolina
Search on here for my past threads, had several about this problem, attempted fixes, etc.
