- Dec 20, 2014
- Lake Worth, FL
- Website
- www.uprproducts.com
- 15 GT
UPR is proud to now offer the all new Double adjustable rear shocks for the 2015 Mustang Eco, V6, & GT.
* Viking Performance Double Adjustable Shock
* 19 positions of compression & 19 positions of rebound adjustment for a total of 361 different valving combinations
* Lightweight Aluminum Shock with a clear anodized finish
* Every shock is dyno tested & serialized
* 5/8" centerless ground, hard chrome plated piston rods
* Precision Machined pistons with PTFE | bronze piston wrap
* Two year material and workmanship warranty. Double the warranty of nearly every other manufacturer!
* Made in the U.S.A. Each shock is hand built in Vikings Lakeville, MN facility
Viking Performance Shock:
Viking Performance stock smooth body double adjustable shocks for your American Muscle. Great for comfortable cruising, high performance handling, drag racing, and everything in between! These shocks give you 19 positions of compression and 19 positions of rebound for a total of 361 different valving combinations.
Every shock is dyno tested and serialized and hand built in the U.S.A. at Vikings Lakeville, MN facility. They feature lightweight aluminum body with a clear anodized finish, precision machined pistons with PTFE | bronze piston wrap and 5/8" centerless ground, hard chrome plated piston rods.
Each shock is covered by a Two year material and workmanship warranty! Double the warranty of nearly every other manufacturer!
Pick yours up for only $194.95 (each)
Click on the link below
http://www.uprproducts.com/viking-mustang-double-adjustable-shock-15.html
NOW..... Let's say your making big power like 800+hp and you are set up for drag racing.... The Crusaders will be the ones for you. Viking Performance takes another leap in high performance suspension with it's new patent pending Crusader high force double adjustable shocks. These Crusader shocks are offered in a variety of valving confirmation depending on the application. Crusader shocks are capable of generating the huge rebound forces often required in race/performance applications to achieve more constant tire patch contact force. The rebound side has 22 available position of adjustments that generate a progressive curve, while the digressive compression has 19 positions of adjustment, for a total of 418 different valving combinations.
Get yours for only $269.95 (each)
Click on the link below:
http://www.uprproducts.com/viking-mustang-double-adjustable-shock-crusader-15.html
If theirs any questions, please feel free to post, PM, or call us at 561-588-6630
