- Oct 7, 2014
- California
- Website
- www.modularmotorsportsracing.com
- Worlds Fastest & Only 5 second Coyote
The Pro Heel Toe blips the throttle to aid downshifting gears on 2015-2023 Mustangs equipped with the 6 Speed manual transmission. This makes for near seamless downshifts to prevent rear lockups, increasing track safety and allowing driver to spend more time concentrating on driving and less on shifting.
Whats sets this kit apart from others is that it is 100% PLUG AND PLAY - No wiretaps, no endless searches trying to locate the correct wire colors and a fraction of the time to install, so no more shop install charges -anyone can install using our easy to follow instructions and coming soon video. Installation is so simple that these can even be installed at the track for your local Autocross, Time trial or HPDE event! Best of all, the Pro Heel Toe uses your phone to make adjustments, thats right, simply connect your phone via wifi and instantly adjust for different tracks and conditions.
Faster lap times are just a blip away!
*Fits all 2015-2023 Mustang GT and GT350/GT350R w/Manual Trans.
*No tune required
*Can be installed or removed in minutes, no wires to cut
*Transferrable to other Mustangs in minutes with your custom settings ready to go!
*OTA Firmware updateable for improved user experience.
This item is great for 2018+ models in which the factory transmission has been swapped for the Improved Tremec 6 speed and the factory blip no longer works.
Installation Instructions
