Steve@CJPP
- Nov 15, 2012
- Harrisburg, PA
- Website
- www.cjponyparts.com
- 2016 Comp Orange GT Prem PP
Classic Design Concepts 1511-7000-01 Mustang Light Bar CV 2015
Add some race-inspired custom styling to your 2015 Convertible Mustang with this CDC Light Bar. The next time your cruising with the top down, you'll surely start turning heads on the street or at the next car show!
This light bar has been engineered and designed to flow with the curves and natural lines of your S550 Mustang. The high mounted LED light provides added safety with a highly visible 3rd brake light. And the best part is, if rain should attempt to spoil your cruise, the factory top effortlessly fits over the light bar as it does not interfere with any original factory functions.
Engineering begins with the construction of sturdy 1-1/4" round steel tubing with a 1/8" wall thickness. Polyurethane is then molded around the tube and finishes hand-wrapped in vinyl, vinyl designed to match the grain of your car's interior trim. The light bar is supplied with the necessary brackets that mount to the B pillars giving the light bar a sturdy mount and also help with stiffening the body. And unlike other light bars on the market, the included wiring harness automatically disables the light when the convertible top is closed, no external cut-off switch needed.
Features and Benefits:
- Custom Race-Inspired Styling
- Flows with the Natural Curves of the S550
- High Mounted LED 3rd Brake Light
- Fits Under Factory Convertible Top
- Sturdy Construction Helps with Chassis Stiffening
- Brake Light Does NOT Function While Top is Up
- Includes All Necessary Hardware and Instructions
*The CDC Light Bar is NOT intended for rollover protection.
Classic Design Concepts creates excitement that enhances the flow of natural lines of the vehicle, while using factory mounting points and hardware to simplify installation and ensure proper tolerances. CDC can provide the average enthusiast and Original Equipment manufacturers with cutting edge style and unsurpassed quality. CDC is one of the top leaders in producing quality aftermarket products you can count on.
Order the Classic Design Concepts Black Light Bar for your 2015 Convertible Mustang from CJ Pony Parts today!
For more Classic Design Concepts parts available at CJ Pony Parts check out:
Classic Design Concepts | CJ Pony Parts
For more styling and light bars available at CJ Pony Parts check out:
Mustang Styling & Light Bars | CJ Pony Parts
For the install video of this item check this LINK
