Tennkid
Since the Shelby has been sitting for almost 2 months now wo being driven, thought i would put a trickle charger on her to keep the battery charged. I have used this same .75amp trickle charger on my truck and motorcycle and worked great. But when I hooked it up to the Shelby battery , the light on the charger never came on and I checked the voltage bf attaching (11.81 v) and left it on for 5 hours and rechecked the voltage and the same (11.81v). So, thought, well the charger has gone bad. So, disconnected it and hooked it up to my truck and the light on the charger instantly came on and I checked the voltage output and it was at 13.6v. So, does anyone know if there is something in the electrical circuitry of the Shelby that prevents you from trickle charging the battery? I connected the leads directly to the battery. Also, is there another charging port for the Shelby to charge the battery other than taking the cover off the battery (very simple process) and hooking to the terminals directly? Any advice is appreciated. One thought is that the 0.75amp charger is not enough for the Shelby battery due to its electronics but just a wild guess, since the charger works on my other vehicles.
