snake bite
- Aug 14, 2015
- Australia - Adelaide
- Fords of course
And this is why I won't be having this recall done.Mine had the recal done on 14/11/2023 and the dealer said they just had to take the tension out of the cable ( not replace a section )Anyway that was all fine then i dropped it in for its service yesterday picked it up and the camera looked like this from a previous post on the US section. So i had to take it back today, meantime yesterday arvo I trying wiggling the cable and could get the camera to go on and off a waver even more. I could even punch it in one spot and it would switch the camera off. So this morning i dropped it off and the camera worked fine and still works fine after they tried wiggling the cable and stripped back the insulation to look for a break. My bet is the break is not physical but inside the wire so it wont show and is currently making contact. They are taking another look tomorrow.
As its a convertible i needed to know that there was another way into the boot if that wire fractured as well and the dealer pointed out the key hole behind the the rear LH passengers seat, so i tried that to make sure it works, it was impossible to turn the key, and i was not game to to use pliers on it. Anyone else found the key release to be very hard to use?
They say its the short subloom in the boot its self between the main loom that curls up there and the camera itself. and that Ford don't cover that under the recall. $192.00 for the fault finding and a New subloom ordered now, which will be $262.00 fitted. I will be phoning Ford on Monday re this, i don't care which bit of the loom got tugged and broken its all the same issue as far as i am concerned. No wiring loom which is pinned down should fracture inside 7 years.And this is why I won't be having this recall done.
