GCSystems
- Jan 9, 2015
- Shingle Springs, CA
- '05 Mustang GT
Ground Control S550 Adjustable Camber/Caster Plates
Now available! Adjustable camber/caster plates for the S550 chassis. These Ground Control plates are designed to work with OEM/stock style springs, as well as 2.25", 2.5", and 60mm inner diameter race springs. Machined from 6061-T3 Billet Aluminum, these plates offer a unique design that allows camber and caster adjustments without removing anything the from vehicle. These plates also include a locking caster frame, which allows camber/caster to be adjusted independently from the other.
From Centerline(stock position), these plates offer:
-21mm of negative adjustment
-7mm of positive adjustment
-15mm of caster adjustment
[/CENTER]
Aurora Aerospace Bearings featured as well as a separate waterproof sealed steering bearing. MADE IN THE USA, these mounts can be built to work factory struts or any aftermarket damper. If you plan to use these with a certain coilover system, retrofit parts are always available if you plan to switch springs/struts at a later time.
Video of install and testing below!
[ame]
Reference discount code "MUSTANG6G" on check out for 10% off total price.
Ground Control Systems
[email protected]
530-677-8600
