Noir5.0
Need some advice from you all, so im in the middle of this grille project, used a 50th anniversary grille and combining it with the grille from the 2014, everything has been carefully cut and I applied bondo to certain areas to make it look as good as possible, at the point where the pieces fit together perfectly but now i need help with holding the pieces together im worried abs plastic epoxy is not going to be strong enough to hold so i was thinkin of spme kind of bracket i can screw into from the back, hard to explain and am open to some out of the box thinking, any ideas??
