XFORCE Bolt-On Exhaust Systems for Ford Mustang 2015-current
Status
Not open for further replies.
XFORCE
Sydney AUS
2015 Mustang
XFORCE is one of Australia’s top exhaust system manufacturers and now they’re bringing their products – including their famous VAREX™ Mufflers – stateside.
XFORCE focuses strongly on research and development which ensures that our diverse range of exhaust products are of powerful engineering precision, stylish and practically designed to maximize performance and most importantly, technically. Our focus on innovation and extensive quality control enables us to provide you with outstanding performance values when it comes to your exhaust. XFORCE is heavily involved in continuous research and development that combines powerfully with their manufacturing advantage in exhaust production and automotive engineering. Their exhaust systems are specially designed and dyno tested by their state-of-the-art Dynapack Evolution 3000 chassis dynamometer machine, for proven maximum performance in the R & D centre in Australia.
WHAT ARE VAREX™ MUFFLERS?
VAREX™ mufflers combine both the design technology of the stock muffler and the performance muffler into one single compact unit. A sophisticated butterfly valve mechanism is implemented to redirect the exhaust gas flow and vary be-tween the two. For higher sound level, the exhaust flows are directed through the opening path and produces maximum power with a robust sound level (or the “sports car note”) and near-zero resistance.
• Easy Installation, no hard-wiring required (in-car 12v socket included) for plug and play functionality
• Durable construction with water resistant plugs
• Dual mufflers control harness available
• Stylish remote key pad
Street Mode: Setting your Varex™ muffler in ‘Street mode’ enables lower sound levels and maximum discretion, as exhaust gases are directed through a chambered path as would a ‘stock’ muffler
Race Mode: For greater power output and sound level, exhaust gases are directed through the opening path and produce maximum power with a robust sound level (or the ‘sports car’ note) and near-zero resistance
In between: As the angle of the valve is infinitely adjustable, it can be adjusted to stop at any point between sports mode and silence mode. This gives you further freedom to set the optimal sound level according to your desired preference.
For more info about Varex mufflers go to http://www.xforceusa.com/products/varex-mufflers
FORD MUSTANG 2015-CURRENT V8
1"7/8 STAINLESS HEADER AND 3" METALLIC CATS
These stainless steel headers are more than just a pretty piece of fabrication. They increase the performance of your engine by extracting the air more efficiently into the rest of the exhaust system. The performance cats will also minimize restriction of the air flow.
Suits: FORD USA MUSTANG GT 5.0L 2015-
Part No.: HS-FM15-KITB
RRP: $1,099.00
Product Type: Headers & Cats
FEATURES: 1"7/8 Tuned-length Headers, Dual 3" 100Cell Metallic
1"7/8 STAINLESS HEADER AND 3" METALLIC CATS AND TWIN 3" CAT-BACK SYSTEM STAINLESS STEEL WITH VAREX MUFFLERS
Upgrading the engine-baclk kit to include our infamous VAREX Mufflers allows you to control the performance and sound output of your car. A simple push of the button can change your car from a light purr to a ground-shaking roar.
Part No.: XF-ES-FM15VMK-EBS
RRP: $2598.00
Product Type: Engine-Back System
FEATURES: 1"7/8 Tuned-length Headers, Dual 3" 100Cell Metallic Cats, Twin 3" Cat-Back System, Oval Center Muffler, Round Rear Varex Mufflers, Dual 4" Tip.
TWIN 3" ENGINE-BACK SYSTEM STAINLESS STEEL
A complete kit from the engine to the tips, it’ll deliver a significant increase in horsepower as well as an exhaust note that’s second to none.
Part No.: XF-ES-FM15-EBS
RRP: $2198.00
FEATURES: 1"7/8 Tuned-length Headers, Dual 3" 100Cell Metallic Cats, Twin 3" Cat-Back System, Oval Center Muffler, Dual-angle-cut 4" Tip.
A performance and sound upgrade that won’t break the bank. The cat-back system not only sounds incredible, the stainless steel finish will compliment your Pony’s rear end perfectly.
Part No.: XF-ES-FM15-CBS
RRP: $1099.00
Product Type: Cat-Back System
FEATURES: Twin 3" Cat-Back System, Oval Center Muffler, Round Rear Varex Mufflers, Dual 4" Angle-Cut Tips
STAINLESS STEEL TWIN 3" CAT-BACK SYSTEM AND VAREX REAR MUFFLERS
Upgrading the cat-back system to include our infamous VAREX Mufflers allows you to control the performance and sound output of your car. A simple push of the button can change your car from a light purr to a ground-shaking roar.
Part No.: XF-ES-FM15VMK-CBS
RRP: $1499.00
FEATURES: Twin 3" Cat-Back System, Oval Center Muffler, Round Rear Varex Mufflers, Dual 4" Tip.
WHERE TO BUY: www.xforceusa.com/where-to-buy
If you have any questions please feel free to send us a PM or visit our website www.xforceusa.com for more info.
mindys
Chicago Suburbs/South Nashville
Mindaugas
2020 VW GTI SE
Interesting system. Can't wait to hear sound clips of the full exhaust. I have two questions:
1. What stainless steel is the entire exhaust system made of? 409 or 304?
2. (Not related to the exhaust) what wheels are on the Mustang in the first picture?
:cheers:
Schu
Las Vegas, NV
S550GTPP
Are you considering selling just the header and merge sections of the system?
I love the header portion of that system.
CEHollier
Prairieville, La.
Charles
2015 GT Premium Magnetic
[ame]
[ame]
Cascadia_302
PNW
2015 RubyRed GT M6 Premium
So is it only fully opened or fully closed with the remote? Anything in the middle?
Flyfaster1
Dallas
15 Magentic PP GT
Looks like it's able to be customized for in b/w the two modes...
"In between: As the angle of the valve is infinitely adjustable, it can be adjusted to stop at any point between sports mode and silence mode. This gives you further freedom to set the optimal sound level according to your desired preference."
Cascadia_302
PNW
I would hope so, but in all the video's I've seen it's either been all the way open or all the way closed.
toplesstripcruiser
Me and Evo: NJ, Mustang: NV
Race Red 50th Mustang GT vert, '03 yellow Evo
Nice concept but I think it just adds complexity to something that should be simple. I mean a separate remote for the mufflers? It's nice and shiny though. Also I don't like the amount of welds on the headers. And that one tight bend. Your more established companies have a one piece design and smoother bends. ALso looking from the back the tips look small and you can see the mufflers.
Demon Coyote
Naperville, IL
2015 Mustang GT
Here's some sound clips from their YouTube channel:
Header + Varex Mufflers:
[ame="[MEDIA=youtube]qyGmc9Qq_iA[/MEDIA]"]
Muffler's Only:
[ame="[MEDIA=youtube]aixTDwTc36w[/MEDIA]"]
Other:
[ame="[MEDIA=youtube]h22k2svr2lY[/MEDIA]"]
[ame="[MEDIA=youtube]NBZFCnjlBy8[/MEDIA]"]
Ecoboost:
[ame="[MEDIA=youtube]a7DkT8J2QDs[/MEDIA]"]
[ame="[MEDIA=youtube]qUkCcD9yyA4[/MEDIA]"]
XFORCE
XFORCE
Sydney AUS
2015 Mustang
Hi all! Thanks for the warm welcome and support. We'll come back with answers to your above questions asap!
RogerS550
Angleton, TX
2015 Magnetic GT Premium PP 50th
What's the difference between the FM15-CBS and the FM15VMK-CBS other than the tips?
RogerS550
Angleton, TX
XFORCE
XFORCE
Sydney AUS
2015 Mustang
Yes you can have the butterfly valve adjusted to whatever angle required. All depends on how quick you are on the button.
XFORCE
XFORCE
Sydney AUS
2015 Mustang
Headers and cat pipes come together, then the cat-back comes as a kit or all together alternatively.
Status
