brandonsmash
SMASH!
- Aug 19, 2015
- Phoenix, AZ, USA
- 2015 GT - PP
Yesterday I installed my brand-new Steeda Tri-Ax short-throw shifter on my '15 GT-PP with 4,500 miles.
Here's my take on the installation and my initial impressions after a day driving around.
First: Fuck you, Boomba Racing (I pre-ordered their short-throw shifter back in September; the post office lost it but Boomba didn't insure the package and so they kept my money less the $66 refund from USPS, and then they threatened to sue me if I left a negative review. Fuck them).
Second: Installation may take about 3 hours if you have access to a lift and your arms are normal-sized. I have neither a lift nor normal-sized arms. I'm a powerlifter rather than a bodybuilder but even still my forearms are pretty meaty and this made installation MUCH more difficult -- it took me almost 7 hours doing this in my driveway (I also don't have a creeper, so it took a lot of wriggling about too).
Prior to the installation I removed my console and taped it off so I could take the opportunity to remove the cupholders. I then plasti-dipped the fake chrome on the shifter surround and cupholders with the same graphite metallic I used on my exterior emblems. I'm quite pleased with the result here. I also took reflective heat tape and taped the underside of the console thoroughly to try to reduce heat intrusion through the trans tunnel.
On install day I started off by removing my Blowfish Racing bracket (this will likely be for sale here later). I'm glad I retained the stock pieces, as I ended up using two of the 10mm nuts that were removed with the BR piece.
From there things started getting difficult. Keep in mind, I'm a big guy and I was working on my back in the driveway. I did slide the exhaust couplers off and I removed the driveshaft bolts, but I couldn't disconnect the driveshaft from the flex coupler. That made installation more difficult for sure.
Dropping the trans mount and lowering the transmission was straightforward enough. I also disconnected the trans tailshaft mounting bracket, which gave me an extra inch (isn't that what all guys want?) or so.
The 10mm bolt holding the assembly to the trans was a pain in the butt to remove, but made easier with swiveling/ratcheting gear wrenches. My forearms wouldn't fit in between the trans and the tunnel, though, and so I swore a lot during this process. . .
. . . but not as much as when I had to remove that goddamn 13mm-head shift shaft pin. My neighbors are now, if they weren't before, very well-acquainted with my proclivity towards swearing creatively and loudly. I did, however, refrain from chucking tools down the street. Ultimately I ended up using a cambered pry bar from inside the car through the shift area to pull up the pin.
Assembly of the Steeda unit was pretty straightforward with their included instructions. Installation was straightforward, even though reinstalling those 13mm and 10mm-head bolts was really, really goddamn awful. (At this point I was losing patience as well as light.)
Putting in the console took me several tries because I was very, very fussy on lining up the reverse lockout collar juuuuuust right. When I went to install the shift knob it simply would not install at all with the Steeda-supplied rubber chord; even with the plug compressed, there was no way to engage the threads. I ended up removing about 3mm from the chord, and then the knob went on just fine.
After driving it for a few miles:
I am EXTREMELY impressed with the quality and engineering of this unit. My piece was shipped in the wrong box (marked S197 SHIFTER), which gave me a moment of panic on Thursday, but it was indeed the correct bit of kit. There were a couple chatter marks and scuffs on the assembly anodizing when I unwrapped it, but really, that's minor: This isn't exactly in a place to be seen. Fitment is top-notch, and this shows very much that the Steeda guys did their homework.
NVH intrusion is substantially higher; I get more exhaust noise coming in through the trans tunnel. Since it's pretty trivial to take off the console I'll likely do this next weekend and add some more Dyna-Mat to surround the entirety of the shifter body. That said, even though NVH is higher (more exhaust noise, some trans noise) this really isn't unbearable (and in fact if I'm honest, it's a tiny bit pleasant -- at least until nuance becomes nuisance). This makes my Mustang at least 40% more racecar.
Recently I swapped trans fluid to Royal Purple, and that was a good move. It smoothed out shifting quite a bit. Combined with the Steeda shifter, there's simply nothing more to be done to the trans. Shift feel is precise and direct. It reminds me of nothing so much as the bolt action from, say, a SMLE wherein the proper means of firing is to keep the middle finger on the trigger and the thumb and forefinger operate the bolt.
Shifting is just right. freaking. there. This is 100% of the 30% claimed throw reduction. In fact, the throws are so short when I first played with the shifter after I'd installed it that I was wondering if I was engaging each gear; they're quite close! Shift effort is just right with the soft springs, and I absolutely wouldn't want the stiffer springs. Reverse takes a bit more oomph to engage, but that's not a big deal.
This is really transformative in how I drive the car. I liked the shifter with the Blowfish Racing bracket, but this goes not one but several steps beyond that. Yes, it's quite a bit more expensive. Yes, installation is MUCH more involved (though to be fair, I had a smaller friend with skinnier arms who helped during the BR installation so maybe I'm a bit colorblind here); I saw some people were quoted about $100 from a shop to install the Steeda parts, and I'd have gladly paid that.
Ultimately I'm very pleased so far with this product. The Steeda customer service is excellent (*cough cough*) and I'll be doing more business with them in the future. The Tri-Ax shifter? Totally, 100% worth it. As of now, I have precisely zero regrets. I now really love how the MT-82 shifts. If you've any hesitation I would strongly recommend that you grab some Royal Purple and do the fluid swap and the shifter install at the same time and absolutely find out what this is all about.
