d4rk_hrs
- Jan 12, 2016
- Life on Air
- Les
- '16 Black GT PP
For those that use or want to use a leaf blower to dry off their cars. I put this together to show how to take it to the next level and improve upon just using a leaf blower.
Can also be referred to as a poor man's master blaster
First you need a leaf blower. When choosing a leaf blower there are three important things to consider when buying.
1. Must be electric
2. You want the highest CFM number that you can find. This determines how much air it can move.
3. Cost. No need to go buy a super high dollar blower.
Here is the one I have. I picked it up at Sears for $34 bucks.
I chose it because it was cheap and has a very high CFM rating
Now let's take it to the next level.
Head to Home Depot and you will need to pick up two items.
The first is found in the plumbing isle. You will need this because mine and almost all of the electric leaf blowers on the market now don't have a round nozzle.
They look like this
I don't know why the change from a round nozzle to this configuration but we won't let that get in the way.
Here is the first item
This is a rubber connector that is 3" on one end and 2" on the other and is $6.99
The second item which is $19.97, make sure you get this specific item. The reason is, the hose on this item is only 7 feet long. All of the other wet/dry vacuum hoses regardless of brand are longer and gets to be cumbersome.
I know you are thinking. Why not just cut the hose. You cannot do that because the hose is flanged on each end and if you cut it, the connector will not fit in the hose.
The hose kit comes with the following three connectors
Use the one on the left and insert it into the 2" opening of the rubber flange. It fits nice and snug and after you tighten down the clamp is not going anywhere.
Slide the 3" side of the flange onto the leaf blower and tighten down the clamp. The rubber will mold itself to the shape of the leaf blower and will be nice and tight.
To prevent any damage from the clamps, screws and to seal all of the openings. I picked up some black duct tape from Wal-Mart for $3.99 to make it look nicer. Can't be all ghetto and use the silver tape
Finally, attach the hose to the connector and here is the finished product
You can use any 2 1/2" wet/dry vacuum nozzle regardless of manufacture because they are all the same size.
I prefer this one
http://www.sears.com/craftsman-2-1-...0916933000P?prdNo=13&blockNo=13&blockType=G13
Now you have way more control and flexibility on where you are blowing and you can even take it to the next level and build a wheeled cart for the blower if you don't feel like holding it.
And nothing was permanently modified.
I hope this is helpful.
1. Must be electric
They look like this
I prefer this one
