Roh92cp
- Jun 27, 2015
- Fort Kent Maine
- Shawn
- OW GTPP Whipple
So from the the get go my front bumper cover to hood alignment was off and left large gaps on the sides of the hood. Seems many 15/16 have this same issue. The center can be adjusted with the hood latch adjustment but that still leaves the side of the hood alignment to bumper cover off. Like mine most have the problem of the front hood sides near the head lights are too high leaving a large gap even the the center to front bumper are flush. Once you pull out the push pins to the top radiator cover you will see the screws that need shimming.
Here is the gap I'm talking about near the headlight hood to front cover.
Here is the small outer most 5.5mm screw, it's hidden under the rubber seal. I have 5 small washers shimming this up. From there work your way in shimming as needed and of course the closer you get to center the less shims/washers you need.
Here is the next screw in from the end toward the center, you can see the shims and you will need less as you move toward center.
