Moody
New to the forum so here we go.
Got my 2015 GT manual (PP) on 2/7/15. Randomly it will takes a few seconds to start, cranks over for about 5 seconds and then fires up like it is out of gas. It is not a cold start issue this has happened in 60 degree weather & garage kept. The most recent occurrence had the long crank issue & a few seconds later the check engine light started flashing, but went off a few seconds later. contacted the dealership and took it in for service yesterday. Dropped it off with only 711 miles. The codes they pulled were PO303 & PO305 and found 2 cracked spark plugs - cylinders 3 & 5. This supposedly cleared the codes and it started perfectly 3 times in a row. the salesman was attempting to deliver it back to me and the long crank issue presented itself again, but no check engine light this time and no codes?!? service manager said he witnessed the issue 3 times today but had no idea as to what was causing the issue. fuel pressure checked out ok too. The dealership is now waiting on a call back from the ford hotline.
anyone experienced this type of issue/problem?
