Our friends at HP Tuners dug into the GT350 Mustang Voodoo engine's PCM calibration files as they have added support for it to its VCM Suite software.
Here's a look at the tables that they sent us:
Perhaps the lower redline is due to this data being collected from a non-R motor? Do we know if the R gets a higher redline?
FWIW, I know in those spy videos of the GT350 and the GT350R on the 'Ring, the R seemed significantly higher-pitched.
Would it be more likely that the 8050 RPM is where the peak torque hits and the 8200 RPM would be the typical follow through on the torque band. If its geared more towards EPA configuration... then wouldn't that 8050 make more sense to see the relevant air to fuel ratios.
The new Ford spins to a heady 8000 rpm before fuel cut-off, according to Nair, and has another 250 rpm of safe headroom.
