Mustang Convert
This has happened to me a few times recently in cold weather (0-20 degrees Fahrenheit) before the car has fully warmed up. If I’m driving say in 3rd gear and approaching a stop sign, I normally hit the brakes, depress the clutch, and shift the car into first gear as I’m approaching the stop sign while the car is still moving. However, a few times, the first gear position feels like it is closed and I cannot shift into that position. Instead, the shifter feels like it is hitting something and will rapidly vibrate/wiggle sideways. If I move the shifter back to the neutral position and then back into the first gear position, it will usually fall into place then, although very roughly (oftentimes the car is stopped by this point and not moving). The clutch pedal has been depressed all the way to the floor, so that’s not the issue. I’ve also had this happen once on a cold 1-2 gear shift, where the shifter just did not want to go into second gear.
I should note that this is my first manual transmission car, so I’m not sure if this is normal. I know others are complaining about notchy shifts in cold weather (I have that too), but haven’t seen anyone mention this issue.
