Jmeo
You said member ;)
- May 28, 2014
- Massachusetts
- Jaime
- 2020 GT500, 2022 F150 PowerBoost
- Vehicle Showcase
- 2
Hi guys, I just wanted to take some time and show you the new Whipple heat exchanger they are now offering. It is dimensionally the same height and length but it is now roughly 4" in depth and is also a dual pass setup vs the single pass of the original version. I will leave the actual numbers to the professional ( [MENTION=13288]Whipple SC[/MENTION]) but I believe it will keep the IC fluid roughly 15Âş cooler than the original version and the surface area has greatly increased. Keep in mind this will delete the fans as they will no longer fit. While installing it we found it held roughly 1/4 to 1/2 gallon more fluid. Here are the pictures taken during the install on [MENTION=26784]4orceFed[/MENTION] 's 16 PP GT. Mine is somewhere between California and Massachusetts as I type!
Compared to the original version this is massive
It's even thicker than the original with the fans still attached
This is very easy to install. It comes with a hose barb and extension hose to reach the other side as it is now a dual pass. It re-uses the same bracketry and upper hose keeping it fairly simple.
Please note the one in the pictures above is a prototype version which is bare aluminum but the final production versions will be black.
Shout out to [MENTION=20657]db252[/MENTION] & [MENTION=16819]Roh92cp[/MENTION] for your participation in this as well :cheers: Such a great bunch of guys!
