RPI Designs
- Nov 18, 2014
- Salem, Ohio
- Website
- www.rpidesigns.com
- 2015 Mustang GT - Test Mule
2015 2016 2017 Ford Performance Hood Lift Kit w/ Laser Engraved Ford Performance Logo $82.00.
Upgrade the engine compartment of any 2015-2017 Mustang S550 with a Ford Performance Hood Lift Kit w/ Laser Engraved Ford Performance Logo. Simply start to lift your hood and let the Hood Lift system take over. Your hood will lift and hold firmly at the raised position - no wind or bumping will knock your hood down on your head. These gas struts are rated at 90 LBS to hold up OEM and specialty hoods.
Due to the leverage when open, a 90 LBS rated strut will keep the hood open securely.
http://www.rpidesigns.com/shop/item.aspx/2015-2016-2017-ford-performance-hood-lift-kit-w-laser-engraved-ford-performance-logo/
Fits 2015-2016 Mustangs - does not fit GT350
90 LBS Rating
Designed for all OEM base Mustang, Mustang GT and many aftermarket hoods
These hood lifts utilize two gas struts that lift and hold the hood without the need for a prop-rod.
Made from lightweight steel and aluminum, they feature a durable black power coated finish to give your engine bay a much cleaner appearance.
Includes the necessary mounting brackets
If your aftermarket hood is lighter than the factory hood, use caution when opening the hood due to the power of the strut.
90 LBS Rating
