RPIDON
2015 Mustang aFe Control Sway Bar Set; (S550) AC-440301001N
Features:
• CNC Bent, Lightweight Tubular Alloy Steel Sway Bars
• 35mm 2-way adjustable front, 32mm 3-way adjustable rear
• CNC machined, TIG welded bar ends offer precise adjustment spacing and a consistent flange thickness for strength
• Includes Polyurethane Bushings and CNC Machined 6061-T6 Aluminum Brackets
• 2 Stage Tangerine Orange, Powder-coated Finish
• Direct Fit Installation, Requires No Modifications
aFe Control is proud to introduce the Sway Bars for the 2015 Ford Mustang (S550). Anyone can make a stiff sway bar, but at aFe Control we provide you with the perfect balance by pairing the proper size front and rear bars together to offer increased roll stiffness without upsetting the vehicles balance and traction control system. Designed specifically for the Mustang, the lightweight tubular sway bars will transform your Mustang’s handling and inspire driving confidence. Cornering will be flatter and neutral in any corner. Perfectly balanced, the 35mm 2-way adjustable front and 32mm 3-way adjustable rear bars are constructed from lightweight tubular steel and feature adjustable, precision CNC machined, TIG welded bar ends for a perfect fit and added strength over thinner, “squished” ends. The kit includes CNC machined 6061-T6 sway bushing brackets that are anodized black and a direct fit for the included polyurethane bushings. For years of durability and great looks, the bars are powder-coated a special 2 Stage tangerine orange. Perfectly Balanced, aFe Control sway bars will have your Mustang (S550) handling just as good at the track as it will around town.
aFe Control Suspension products are engineered and manufactured in our Corona, California manufacturing facility.
Fits: 2015 Ford Mustang I4/V6/V8 Models.
Please note, we sell the Sway bar as a complete set, or just the front or just the rear. Please make you correct selection when ordering.
Item # AC-440301001N Use Coupon Code RPIDON5 when ordering on line or by phone and receive 5% off the listed website price!!
Website link : http://www.rpidesigns.com/shop/item.aspx?itemid=5536
Features:
