- Feb 1, 2016
- San Luis Obispo Calif
- Website
- www.hotpart.com
- Bob
- 2015 Mustang, 1959 Thunderbird
2015-2018 Mustang GT, EcoBoost, IRS Support Brace Jacking Rails J&M Products
NOW PATENT PENDING
This new J&M Product has been designed to work with the Steeda Part # 555-5754 Rear Subframe Support Brace.
2015-2018 Mustang GT, EcoBoost, IRS Support Brace Jacking Rails J&M Products are CNC laser cut and tig welded. Utilizing a machined insert that gets welded into the rail to provide maximum strength and rigidity. The inserts are machined from high strength carbon steel piece that gets tig welded, then the end caps get welded to keep out the road grime/weather preventing rusting and corrosion. No cutting, drilling welding or other modifications are needed to install the new rails. Rails add additional rigidity to the chassis, jack the entire side of the car from one convenient location.
Rails are designed to fully protect the rocker panels and the factory jacking points while being fully compatible with the Steeda Rear Subframe Support Brace P/N 555-5754. When jacking up the sides of the car at the track, doing oil changes and during “off roading” the rails protect the factory pinch welds from damage/folding and collapsing.
These jacking rails can be installed very quickly, simply remove the factory hardware on the underside of the rocker panel at the front and rear of the car. Next use the included hardware and bolt the new jacking rails to the underside of the car. That is all that it takes for the installation, simple, quick and very easy.
Jacking Rails are available in either Red powder coat (25510R), Black powder coat (25510B) or for those that might want to paint them the same color as the car, a bare finish (25510).
- Designed specifically to work with Steeda Rear Subframe Support P/N 555-5754
- New hardware is included
- No cutting, welding or modifications needed
- Installs in minutes
- CNC laser cut and tig welded
- Unique machined metal insert for added strength and rigidity.
- Made in the USA
[*]PATENT PENDING
