BMR Toe Link(TR005) and Steeda Camber Arms(555-4123)
johnny.3sgte
DFW, Texas
2017 Mustang GT
Installed the BMR Toe Links (TR005) Sunday afternoon along with the Steeda Rear Camber Arms (555-4123), both adjustable. Already posted this in my "Build Sheet," but figured I'd post it here as well to give customer feedback for future buyers.
Both were a pretty straight forward install, although I must say the Camber Arms was a tedious install. There's no room for a ratchet when getting to the inner mount bolts of the arms, so I was turning maybe 1/8th of an inch every turn of that with a wrench. The passenger side has enough room for a ratchet though, so that was a breeze. "Install Tip": dab a little grease on the lockout tabs, otherwise they'll just keep falling out of the hole when trying to slide the bolt though. Per the instructions of Steeda, you have to install the bolts reverse of how you pulled them out? I didn't see why, so I just put them in the way I took em out. The BMR toe links were a straight forward install, didn't run into any problems there.
At first, I was hesitant about ordering the Steeda Camber Arms -- I'm the type of person to just stick with one brand, as they work better in sync when all from the same company. The adjustability range is what sold me on the product. But I must say, I'm in love with the beefyness of the Steeda Camber Arms. They certainly are a sight for sore eyes, I also wish they came in red to match all the BMR parts. But I couldn't be any happier nonetheless on the purchase. The BMR toe links are also a beauty, but what more can you expect from BMR! :cheers: Here's some photos comparing them to the OEM ones, wish I could've remembered to weigh them to see if there's a difference.
Pictures of them installed on the car, I adjusted it the best I could by eye. You'll see how I did on the alignment sheet at the bottom haha
Here are the final alignment specs, running the stock 18x8" wheels with 235/30 PZero tires -- figured I'd wait on the Enkei RPF1s for the time being and purchase the Corsa Extreme exhaust this summer or spring. I'll replace the stock Perelli's with 255/45 NT555 when the tread starts wearing down more. But for the time being, all the suspension components are done in my build aside from IRS bushings that'll come later down the road.
Here's what's on the car for suspension wise so far:
  • BMR (SP083R) Handling Springs
  • BMR (SB043R) Front and Rear Sway Bars
  • BMR (CB005R) IRS Cradle Bushing Lockout Kit
  • BMR (TCA047) Aluminium Vertical Links
  • BMR (CP001H) Caster/Camber Plates
  • BMR (TR005R) Adjustable Rear Toe Links
  • Steeda (555-4123) Adjustable Rear Camber Arms
  • KONI Yellow Adjustable Struts; (Front and Rear)
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
Awesome! Thank you for sharing!
Killer suspension set-up!
Mootang
Sacto, Caliunicornia
Henry
2017 Mustang GT
I am thinking of switching to the BMR toe link from the Steeda ones. I like the red color :)
BMR Tech
Tampa, FL
Dion
When you get a chance, I highly suggest grabbing the Ford M-5A460-M Toe Bearing.
AM usually sells it for about $65...and it is a GREAT mod. ;)
2016s550gt
Northern California
2020 Mustang GT
I wonder why my BMR toe links are not boxed on one end like yours. Also for the bolts that came with them, all 4 are long ones
johnny.3sgte
DFW, Texas
2017 Mustang GT
I told the girlfriend no more car parts for awhile haha but I'll definitely check it out when I order the exhaust, Kelly!
I wonder why my BMR toe links are not boxed on one end like yours. Also for the bolts that came with them, all 4 are long ones ��
Maybe you got a newer/older batch or vice versa? My package didn't come with nuts for the bolts either, so I went to Home Depot and grabbed a set and used Loctite on them.
BMR Tech
Tampa, FL
Dion
[MENTION=26096]2016s550gt[/MENTION] the gussets were added a few months back. They were just a "running change" we made. We develop and supply parts to other companies and race teams etc - and one of those said companies requested we add them. The non-gusseted design is fine. It has been tested on the worlds fastest road course AND drag race S550 Mustangs, so don't worry my friend. ;)
Rebellion
Houston
2016 Competition Orange GT
Just missing the LCA and toe/knuckle bearing on the build! :thumbsup:
GTPP
Sacramento
2015 GT PP
Does anyone make a tool to R&R the toe knuckle bearings? I've been hesitant to install mine because I hate using those universal ball joint presses.
Mootang
Henry
2017 Mustang GT
I tried the DIY way and used a ball joint press. It failed because Ford gave out the wrong size and I almost lost a socket. I ended up finding a shop where I can bring the whole LCA to and had the LCA bearing and toe knuckle pressed in.
wildcatgoal
@sirboom_photography
TBD
I used a universal press. Was a pain, but it worked. Ford's socket size was wrong, I just used a larger socket size that happened to be perfect. Universal press will do it, but use some packing tape to tape the cups you line up together so they don't fall apart all the time just when you are getting everything situated.
Bankss550
Bucks County PA
Maurice
2016 Magnetic GT Premium 6SPD
Does it matter which way the "gussets" face? I noticed in OP's pics that they face down so I assume that's correct. I ask because the instructions don't specify and I want to make sure when I install them, they face the right way.
Burkey
Australia
Im running the Steeda adjustable arms with BMR toe rods also. One thing I found at install was that the boxed end of the BMR toe rod had to be flared in order to fit over the Ford racing Toe-Knuckle bearing (too narrow in the opening).
I used a bolt with two nuts trapped between the box section to flare it open a little.
I'm sure there's other ways to to do it "nicely".
The result of all that plus LCA bearing is phenomenal.
Mootang
Henry
2017 Mustang GT
I too would like to know this please.
