Jmeo
You said member ;)
- May 28, 2014
- Massachusetts
- Jaime
- 2020 GT500, 2022 F150 PowerBoost
- Vehicle Showcase
- 2
I recently installed a Mishimoto Oil Cooler, Trans Cooler & Radiator on my 2017 GT which I am also installing my Whipple 2.9 supercharger from my last car. I wasn't sure if the oil cooler would fit with the Whipple heat exchanger & fans but I decided to get the kit anyway and I am happy to report it does fit without any modification. Here are some pictures of my install.
Here is the install video they have posted on youtube. The kit does not come with directions.
[ame="[MEDIA=youtube]C8Qx5_pwCVg[/MEDIA]"]
I opted for the black oil cooler because I didn't want it to stand out. The spacers that are used to hang the oil cooler from the Mishimoto supplied air diverter are unpainted aluminum so I wrapped them in electrical tape. There was enough tape material left on the top & bottom of the spacer to be sandwiched between the cooler and air diverter so it is sure to not come unravelled.
The AN fittings and the braided hoses are silver in color so I decided to put wire loom over the hoses where they would be visible through the grill. The AN fittings I left silver for now, if I don't like them being seen I'll either shoot them with spray paint or cover them with loom as well.
I wasn't sure if the oil cooler was going to clear the Whipple heat exchanger but as you can see it clears without issue.
Here you can see the two lines running down and around the Mishiimoto radiator before and after I installed my Whipple reservoir tank & pump.
Here are the two lines connected to the sandwich plate. I was able to use the two 1/4" NPT fittings to insert an oil pressure and oil temp sending unit. This is great because I wasn't sure how I was going to attach these otherwise. Another reason to be happy about the oil cooler if you ask me.
The replacement lower radiator hose which deletes the stock coolant oil cooler lines.
The radiator is plug and play, it's just a swap and you're good to go. Here is a comparison to the non PP GT radiator.
The transmission cooler was also pretty straight forward. This is the tool I needed to disconnect the transmission lines.
Here is a comparison picture to show just how much bigger the Mishimoto Trans cooler is and how it attaches to their radiator. It will attach to the stock radiator the same way.
https://scontent.xx.fbcdn.net/v/t31...=a885af6d129bb980d913a33eca437984&oe=58E6911E
Do yourself a favor and get the hoses aligned just right otherwise getting it into place will be a little tough. Once I figured out exactly how to attach them it went in pretty easy. I did end up swapping the fittings that came on the two hoses around and cutting a couple of inches off one of them. This is how I aligned them.
I used the piece I trimmed off to slide over the mounting tab to protect the rubber line.
Radiator & Trans Cooler installed and looking awesome
I am very happy with all three of these items, they are top notch built and fit & finish is perfect. I thought some other people would be glad to know that one or all of them fit with a Whipple supercharger
