Grey16gt
It's been kind of a long process. some of you may remember an earlier post where I had ordered one wheel and mounted one of my tires. Istarted figuring out how I can make them fit with no rubbing. I succeeded there is no rubbing anywhere at all everything is very very close but nothing touches. I've taken it out on back roads lots of bumps and humps brought it back home and can't find any rub marks. one thing that surprised me was when the car is up in the air the tires will rub a little turning the wheel lock to lock. on the ground it does not rub. I can turn all the way right and all the way left and not rub the tire anywhere. I'm running no spacers. The two things that helped me the most was the Ford Racing struts ware just underneath the spring perches flattened. And the steeda camber bolts the car is perfectly in alignment. It was the camber bolts that gave me just a little bit of extra space I needed to make it all work. Thank you Steeda! Also wanted to thank the guys at Mrr for the great job on the custom paint. And Jake at Vibe Motorsports. No matter how many pictures I tried to take I just can't seem to get the wheels to come out right. The pictures make them look like they are just painted a copper color. But in actual you actually see through the paint to the brushed aluminum underneath. And I absolutely love it. what do you guys think?
