HAHAHA Let's make it happen.....Damn Velgen, you had to post this?! Take my money please.
You need the 8mm spacer to clear.Would it work without the 8mm spacer?
It needs it to clear the struts and such sir.Would it work without the 8mm spacer?
Thank you sir, I could never find your car anywhere, lol. BTW Love the car ! :ford:Here it are some pictures of my car with Velgen Classic 5 20 x10.5 45mm offset. 8 mm spacer up front with ARP longer wheels studs. 305/30-20 Nitto 555 G2 on all FOUR.
Depends on the drop but yes it should work on a mild drop. Remember you do need a small spacer up front for clearance.Would 305/35s fit on a square 20x10.5 setup?
Cool, I prefer more meat and I won't be dropping that much. Starting to strongly consider a square setup so I can rotate and avoid tramlining as much as possible.Depends on the drop but yes it should work on a mild drop. Remember you do need a small spacer up front for clearance.
Yea a lot of guys are leaning towards that direction. With the right tire size and drop the car still looks great. It will also definitely handle good too.Cool, I prefer more meat and I won't be dropping that much. Starting to strongly consider a square setup so I can rotate and avoid tramlining as much as possible.
You can most probably get away with doing a 35 series. As for color silver will give you a clean look and the gunmetal would look more aggressive on the white. its all about color preference. Ill attach some photos so you can see the different options.This is happening. So for a square 10.5x20 set up...
-8mm spacers up front
-Extended wheel studs up front (3")
-Open spline drive lug nuts (not sure if open is necessary)
Sound about right? As for tires, 305/35 would be preferable to make gearing a bit taller as I have the 3.73's. I am lowered 3/4"F and 1/2"R on BMR SP089/82. So Hoping I could get away with 35 series. And I am torn between the silver and gun metal on Oxford White. Both look so good!
