2015-17 Mustang Steeda Short Throw Shifter Tri-Ax Street
Status
Not open for further replies.
CJ Pony Parts
Harrisburg, PA
www.cjponyparts.com
A large variety of Mustangs across all generations
Just like any retail business, from time to time we get returns. A lot of times there is little to nothing wrong with the actual product and more often than not a customer just changes their mind. Luckily we have our eBay Store which will allow us to pass on great savings to people that aren't worried about a possible scratch or dent, maybe a missing washer, nut or even instructions.
If a used, returned or discontinued item is posted on our eBay Store, we try to take as many photos as possible and explain what (if anything) is missing and/or damaged. Below is a perfect example of this.
Steeda Tri-Ax Street Short Throw Shifter for all 2015, 2016 and 2017 Mustangs with a Manual Transmission.
Item condition: New other (see details)
"This shifter was previously installed."
If you just picked up a new 2015-2017 Mustang and you’re looking for a little more out of that stock, sloppy manual shifter, then look no further! Steeda has your answer with their new Tri-Ax Street Short Throw Shifter designed specifically for your 2015-2017 GT, EcoBoost or V6 Mustang, available right here at CJ Pony Parts.
Features and Benefits:
- 30% Throw Reduction
- Made With High-Quality Billet Steel for Durable and Reliable Operation
- Coated in a Nickel-Plated Finish for Great Looks and Corrosion Protection
- Zero Increase in Shifter NVH (Noise, Vibration and Harshness)
- Includes a 360-Degree Enclosed Reverse Lockout
- Detailed Installation Instructions Included
With a relatively easy installation, this Steeda Tri-Ax Street Short Throw Shifter is the perfect choice for your S550 Mustang. Made from billet steel for a solid and reliable operation, this shifter is coated in a nickel-plated finish for great looks and corrosion protection. This manual short throw shifter also features a 30% in throw reduction and doesn’t increase NVH so you can dramatically improve your overall driving experience!
Please Note: Accepts factory shift knobs and aftermarket knobs with M12 x 1.25 thread pitch. Easy to install and does not require any permanent modifications to your Mustang.
THIS IS A FINAL SALE THERE WILL BE NO RETURNS OR REFUNDS ON THIS ITEM
Status
