Factory cams in 2016 mustang gt
Bill88stang
2016 deep impact blue premium gt 6 speed manual
Did I read somewhere on here that the cams in out gen 2 coyote uses the boss 302 intake cam and the cobra jet exhaust cam?
AmericanLegend
2016 Mustang GT Premium w/ PP
Not exactly what your looking for, but:
Stock Gen2 Coyote Intake/Exhaust valve size and lift:
Intake 37.3 mm/13 mm, exhaust 31.8 mm/13 mm
Cylinder Heads:
The 2015-16 Coyote (Gen 2)
cylinder heads have improved ports and larger valves
– and flow as good as the 2012-2013 Boss 302 CNC
ported heads.
Camshafts:​
The Gen 2 camshafts are 13mm lift
on the intake and exhaust, which is 1mm of added lift
vs. the Gen 1 Coyote.
Valve Springs​
GEN 2 valve springs are higher pressure that the
standard Gen 1 spring - and are the same valve
spring as used on the 2012-13 Boss 302 Coyote​
engines
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwj8346Z0KTSAhVGqlQKHRJQBJ4QFggaMAA&url=https%3A%2F%2Fperformanceparts.ford.com%2Fdownload%2FPDFS%2FFPP_Gen_2_Coyote_Technical_Reference_2-16.pdf&usg=AFQjCNGPzE8dTjaD6DH2yDP3aALlhc_YTw&bvm=bv.147448319,d.amc
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
Here is some good data. :thumbsup:
Legionofone
2016 Mustang GT Base
May wanna add a guide to what each part number means.
BMR Tech
Tampa, FL
Dion
09jsw
East coast
2015 Guard PP GT
The stock exhaust cams are the actual boss cams. The intake cams are nothing that's been used before. Data is on svt performance forum.
