Steeda's New Adjustable Front Coil Over Kit
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
Steeda's New adjustable Pro-action coil over Struts.
They will be available in 30 days.
Spring rates available from (150 lbs/in) to (400 lbs/in)
Competitive pricing coming soon!
jbailer
Joe
Very nice! Congrats!
slink914
Tampa
2015 Eco
This is exactly what ive been looking for, now when are the rears coming out. Koni's made to Steeda specs?
SteedaTech
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
They are made for us by ITT the same company that makes the Koni.
Plus, they are made to our valving spec and have a lifetime warranty.
The rears will be coming out in 60 days. It will be the adjustable rear spring seat which is placed in the upper sub-frame.
We have seen a lot of durability concerns with the true coil-over in the rear which is placed on the outboard side of the trailing arm.
SYK
Atlanta
2015 EB Premium PP Auto
I agree S550 Chassis doesn't allow a durable true coil over design in rear since the shock will always have to be mounted in shear direction.
Grim12
2016 GTPP
You guys are killing me!
Performance nut
TX
2018 Mustang GT A10
Ha... And I still have the Steeda adj pro actions waiting for springs to be installed. Should have waited.
When is your hybrid spring going to be released?
SteedaTech
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
You are correct, Also, the rear mount that attaches to the wheel well sheet metal starts to oil can going over irregularities in the road. We documented this in testing.
slink914
Tampa
2015 Eco
That's a very good point.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Called this as soon as I started seeing coilover kits mounting there...
apex15stangPP
PHX, AZ
J
2015 Mustang GT PP
What??????????????????? If done right, there are no issues. All the Ford Racing S550 cars have a rear coilover
SteedaTech
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
BmacIL
Enginerd
Naperville, IL
The highest force the damper mount area has to take up with a PP shock, for instance, is ~250-270 lb. Since the Shelby has significantly higher rates it's fair to assume the dampers might exert in the neighborhood of 400 lb. Even with a safety factor of 2, you're at 800 lbs, which the stock GT rear spring rates would do easily at that location, without damper force included. You're looking at well over 2000 lbs of force at that location with a high rate (street-focused) spring, let alone what some of you guys are running for autocross-only setups. Sure, if you distribute the load well, you can probably make it live, but it wasn't designed to take the spring loads in addition to the damper's.
The GT350R-C/GT4 looks to have a mount that distributes the load well & differently than a stock S550:
http://img.photobucket.com/albums/v629/BulIitt68/Mobile Uploads/image_9.jpg
apex15stangPP
PHX, AZ
J
2015 Mustang GT PP
I'm covered!!! :) Beefy!!!
