you go extreme brotha lol and I like it.I ran a 20x10 +22
ET 40 19x10 with 275/40/19 will be also good for Performance Pack ?The front dynamic of the car is amazing you can run the following
20x10 ET 20-40
275/40/19 & 285/35/20
All depends on the wheel.
Not up front, unless you are running a narrow tire.Is a +48 offset acceptable for 19x10?
Yes, but it's not just size and offset. Some 19x10 ET40 wheels won't clear the brakes.ET 40 19x10 with 275/40/19 will be also good for Performance Pack ?
Naw, +35 is perfect.i think 10in +30 is perfect
Adapters right brotha?I've got MMDs 20x10 with a 45 offset. Super tucked in. I like to be flush. I'm using a 25mm spacer so essentially a 20 offset. And it's just about flush. I use 20 spacers on the rear too. No rubbing and I'm lowered on Steeda progressives.
