Dominant1
http://www.jpcracing.com/2015-tremec-magnum-xl-complete-conversion-kit/
*** 2015-up Models will require you to clearance the tunnel some for the reverse lock out ***
Known unofficially as the Magnum XL, this new 6-speed model will feature a direct-shift extension housing designed to eliminate the notoriously unpopular semi-remote factory shifter. Additionally, a slip yoke style interface will also make it easy to ditch the equally unpopular 2-piece driveshaft in favor of a more robust 1-piece arrangement.
As with all Magnum 6-speeds, TREMEC aims to put a 700 lb-ft. seal of approval on the new Mustang units, and will eventually offer them with both Magnum ratio packages to suit a variety of street and performance driving scenarios.Great solution for 2011+ Ford Mustangs with fragile factory Getrag MT-82 transmissions! Also replacing the weak TR3650 and the shifting issue prone TR6060.
Two different ratio options are available:
2.66:1st 1.78:2nd 1.30:3rd 1.00:4th 0.74:5th 0.50:6th2.97:1st 2.07:2nd 1.43:3rd 1.00:4th 0.80:5th 0.62:6th
Transmission will work with OEM slave cylinder
***2015-up require the Speed Calibration Box which is added into the cost of the package when selecting your vehicle***
***Aftermarket flywheel REQUIRED for 2007-up GT500 and 2011-up GT/Boss. Highly recommended for all applications***
Included in kit:
- Magnum T-56 with your choice of gear set
- Quicktime SFI bellhousing
- Crossmember & Mount
- Shifter Assembly
- Driveshaft shop Aluminum Driveshaft w/ Spicer Yoke
- SPEC Stage 2 Clutch Assembly
- SPEC Billet Steel Flywheel
Features:
700lb-ft Torque Capacity 2.97 or 2.66 1st Gear 26 T Input Shaft Spline 31 T Output Shaft Spline
