bluestang21
Just wanted some input as to what the best bang for your buck mods are. Thanks!
i would prefer to start out with easy suspension mods installation-wise, any suggestions?Depends on what you're after as far as performance. If you drive a manual, then a short throw shifter is a huge improvement. MGW, Steeda Tri-Ax or even a Barton would be a nice upgrade for you. An exhaust is great on many levels (performance, butt-dyno, sound, etc.). And when it comes to suspension, there's huge room for improvement over stock.
Eddie
Thanks a lot. Would sway bars also be a viable option?Next would be some progressive springs. That's a little more involved, but the car handles nicer on turns and the stance of the car will look much meaner. Gets rid of the horrible gap between the tires and the wheels well.
http://www.steeda.com/steeda-mustang-sport-springs-progressive-2015-gt-v6-coupe-555-8210/
Definitely. I would start with trying to eliminate the wheel hop and really putting your power to the ground. Then move onto sway bars to handle the corners. I was pretty content after adding the bushing supports, IRS brace, toe links and vertical links. And I heavily recommend the alignment kit. It's cheap and and it'll make sure your subframe is aligned.Thanks a lot. Would sway bars also be a viable option?
See Eddie's first sentence in post #2.Just wanted some input as to what the best bang for your buck mods are. Thanks!
