Help with Check Engine Code P144c
Hiei
Dallas
2016 Mustang Ecoboost
I was doing some aggressive driving then I noticed the check engine light came on , read the code with the accessport , says purge evap valve emissions , anyone ran into this code before and what should be my next move ?
Chef jpd
Brooklyn, NY
Clear it with your AP.
See if it comes back. That is one of those codes that appears, and never to be seen again.
While you are there, do a KAM reset. Actually that is good to do on occasion.
Hiei
Dallas
Ok cleared the code started up just fine , went back to reset the KAM and when I started it up it stuttered a little bit then started up , is that normal . . ?
Chef jpd
Brooklyn, NY
Yes. It hiccups a bit. What you are doing is clearing the keep alive memory.
So if you drive like a granny, it learns granny driving.
Clearing it every once in a while keeps it more "alive"
jbailer
Joe
In the Helm manual it says it will run a little rough when you first start it after a KAM reset. It says something about letting it idle with the AC on for a couple minutes before driving.
Hiei
Dallas
Oh ok cool , damn I got scared , so I reset the ECU , took a memory snap shot , retuned the car and just came back from driving and it ran fine .
Chef jpd
Brooklyn, NY
You don't need to retune after a KAM. See if you can notice a difference after a reset.
Ill bet you feel a much sharper throttle response.
Let us know if the code returns......
DUNDEM
Miami
2015 Base EB PP
Just sharing...
Had a P144A-EVAP Emission System Purge Vapor Line restricted or blocked.
Came about after piking the car up from the dealer the day before for my second AC repair. They did replace a part if it mattered. I'm on the stock tune, never been tuned.
Hiei
Dallas
This code keeps popping up every other day after clearing it , maybe there's an actual problem ?
Regs
Mustang 2016 Echoboost
Exhaust issues so soon could mean another underlying issue. Like too much gas is escaping into the exhaust and igniting after it leaves the engine because you are running too rich or the spark is not hot enough to ignite the fuel.
Hopefully just a defective exhaust part.
Hiei
Dallas
Well I did just replace the spark plugs about 2 weeks ago , not sure what could be wrong with the exhaust , I have Borla ATAK Catbacks installed . . haven't had any issues until I replaced the plugs just recently
MiDiablo
#JustA4Banger
Spring Hill, FL
www.youtube.com
Josh
2018 Mustang GT PP 400A 10R80 RTR Spec 5 Widebody
Check to make sure the harness is fully plugged in on the purge valve. The purge valve is the little canister on top of the intake manifold on the driver's side. It's about dead center on the manifold there, with a little metal bracket holding it up off the intake manifold. There's a harness jumping to it from the spark plug portion of the harness. It may have come disconnected at some point during your installation of the spark plugs, as you're working in that area a considerable amount when swapping them.
MiDiablo
#JustA4Banger
Spring Hill, FL
www.youtube.com
Josh
Also, make sure that the line coming off of that valve (and going into the top of the throttle body) is plugged all the way in and the little red clip is holding it into place.
