Ford Mustang EcoBoost Wastegate Actuators Available At RPI Designs
Status
Not open for further replies.
RPI Designs
Salem, Ohio
www.rpidesigns.com
2015 Mustang GT - Test Mule
2015 2016 2017 Ford Mustang EcoBoost Wastegate Actuator Available in 7,10 and 12 PSI
No one knows EcoBoost better than Turbosmart. They make performance parts for every Ford EcoBoost application, not just here in the USA but all around the world. This wastegate actuator is another example of how Turbosmart is at the leading edge of turbo performance for the Ecoboost Mustang.
Turbosmart has designed a brand new Internal Wastegate Actuator for the Mustang EcoBoost, which can help owners get more performance out of their engine with little effort. Turbosmart's 12psi Internal Wastegate Actuator creates a flatter boost curve which comes on sooner, with more stable boost and less drop off at the end of the rev range compared to the stock actuator. The result is a more driveable car with smoother power delivery and less turbo lag.
This actuator is ideal for modified and tuned vehicles. You can expect an increase of 3 to 4psi (peak boost) but the real improvement is in the mid-range.
Turbosmart's Internal Wastegate Actuator is stronger and more durable than the stock wastegate actuator, and is highly customisable with interchangeable springs for a range of boost levels, so it can allow the EcoBoost engine to release its full potential.
FEATURES:
• Silicone diaphragm with Nomex reinforcement to withstand high temperatures.
• High grade, billet aluminum construction.
• Stainless steel rods and connecting clevis for corrosion resistance.
• Locking Collar design cap allows for quick spring changes.
• Ideal for use with any Turbosmart boost controller.
7 PSI Here
10 PSI Here
12 PSI Here
Status
