BallisticBurrito
- Nov 14, 2015
- Louisville, KY
- 2015 GT
Yeah those jack rails are pretty handy.
Correct. See belowso you jack from the center of the rail and then place the stands at either end of the rail... then repeat on the other side?
that does sound super easy.. I will definitely consider it next time I have to do something under the car
They are sooooo nice!Yeah those jack rails are pretty handy.
I did my cat-back on just ramps. The front bolts on the resonator required a bit of a squeeze but it wasn't hard.Good info. I have ramps so i should be able to put the front end up and then just jack up and use stands for the rear when its time to install my exhaust. I do plan to get the jacking rails just doing other things first.
Are you a big guy? I ask because I'm a muscular 250 and will be doing my catback this weekend. IDK if I can fit if I put the rear of the car on ramps.I did my cat-back on just ramps. The front bolts on the resonator required a bit of a squeeze but it wasn't hard.
I'm a cuddly 310 and can fit underneath. I thought about bench pressing it, and holding with one hand to do the work, but used the ramps instead.Are you a big guy? I ask because I'm a muscular 250 and will be doing my catback this weekend. IDK if I can fit if I put the rear of the car on ramps.
On another note, it looks like jacking rails will be in my future (after this weekend).
You'll be fine to get under the car. Most 3 ton jack stands have plenty of height to get under the car comfortably. If you're lowered that's another issue... unless your jack is low profile you may need to drive the front tires on a couple 2x4s (or a 2x6+) for additional clearance for the jack.Are you a big guy? I ask because I'm a muscular 250 and will be doing my catback this weekend. IDK if I can fit if I put the rear of the car on ramps.
