stinger556
- Oct 31, 2015
- San Diego/Ft Campbell
- Family hauler, for now
2016 Cadillac Escalade weighs 5,815 lbs
It has a 420-HP, 460 lb-ft torque, 6.2L Vortec V8.
It gets 23-25 MPG on the freeway.
The 5,815 lb Escalade does 0-60 in 5.8 seconds.
This same motor is found in the Silverado 1500, which does 0-60 in 5.6 seconds.
Why is it that Ford has an all-aluminum F-150 with the EcoBoost 3.5L V6, and has much worse performance and worse gas mileage then the V8? Hell, even the 390-Horsepower 5.0 V8 that ford offers in the F-150 gets better MPG and is just as powerful as the 3.5L EcoBoost V6 - they both have nearly identical 0-60 times.
Then you add in the fact that the EcoBoost turbos are prone to failure and generally are a higher-maintenance motor then the NA V8 5.0. And don't even think about turning up the boost unless you want a new truck with no warranty.
Towing figures are also identical, with a slight edge to the 5.0 V8 (when towing 5,500 lbs, the V8 has the edge with MPG and 0-60 times).
My theory is that Ford has marketed the EcoBoost so well to reflect the image of a 'greener' company, knowing that the average person won't realize the discrepancy in numbers compared to the V8...and they certainly don't want you to know that GM has built a NA V8 that is far more efficient and more powerful.
Don't take my word for it, do your own research. I'm a Ford fan, by the way - but that doesn't mean I drink the EcoBoost koolaid
