RPI Designs
- Nov 18, 2014
- Salem, Ohio
- Website
- www.rpidesigns.com
- 2015 Mustang GT - Test Mule
2015-2017 Ford Mustang Coupe WindRestrictor w/Lights Starting At $374.70 With Code PHIL5 At Checkout.
The WindRestrictor® brand Glow Plate for the Ford Mustang 2015-2017 the rear mount attaches by slipping under the rear headrests. The headrests must remain in the "UP" position once installed. This item is specially engineered to remain in place once installed. The installation of this windscreen requires no drilling or permanent modification. A lifetime warranty is included with your purchase which guarantees that the product will never fade, yellow, peel, or crack like others on the market.
*Made from double-sided AR Polycarbonate.
(Very durable acrylic type material is also scratch resistant! Others are made out of much cheaper materials and dangerously breakable plastics. Some may be made out of Lexan; the disadvantage to Lexan is that it scratches easily and won't emit illumination, It may also discolor with etching.)
*Professionally precisely designed and laser cut.
(Others are produced at home using table routers and jigsaws leaving rough edges and defective shapes. Wind Restrictors™ are professionally produced from the finest materials using state-of-the-art equipment.)
Get it here https://www.rpidesigns.com/shop/item.aspx/2015-6th-generation-ford-mustang-coupe-windrestrictor/
See this part in action here.
MUSTANG6G Members Save With Code PHIL5 At Checkout.
Check out This And Many More Mustang Parts On Our Website RPIDesigns.com
