Clutch spring removal? Am I the only one that it's not easy for?
armykyle1 [HACKED ACCOUNT
Gulf Coast
2018 GTPP premium
I pushed my clutch all the way in and I could slide the bottom part the clutch spring off. Took. 5mim, if that
altjx
altjx
GTFO_0036 | 1337 h4x3r
Atlanta, GA
www.altonj.io
Alton J.
2017 Race Red GT350
Yeah. I wish I had known this when doing mine initially. There's no need to use any tools -- that's only going to make it more complicated and cause frustration for people like me. For you guys that are suggesting using vice grips and stuff, have you tried just simply pushing in the clutch and sliding it out? Does it just not work that easy for some people? I don't really understand why tools are suggested in the first place unless it's just not that easy to slide out for everyone.
TexasRebel
Gearshifter
between the mustard and the mayo
2016 YZ GTPP - PP2
In such an awkward position in the first place, I could barely get any leverage on the spring, even when the pedal was depressed. I also didn't know how much preload was on the spring, and how much energy I was about to release in front of my face.
Experience says you don't want uncontrolled release of a loaded spring.
Grabber By The Bluesy
LOCATION
2017 Grabber Blue Mustang GT Premium
I just pulled mine out, took less then a minute with some grunting!
Question is, Steeda spring aside, whats the longest anyone has gone without one in and has there been any problems? I chipped a small piece of the side of the plastic top portion but it looks like its still usable in case I do get the Steeda spring.
jwhite
jwhite
Indiana
J. Brad
15 Gt PP Roush SC'ed/16 GT 350 TrackPack 1970 Mach1
My supercharged 15 GT/PP has been with out spring sense Nov of 14, 12k miles and my 16 350 has been out sense June of 16 only about 3200 miles. No issues. I tried the Steeda but the clutch still just felt numb to me.
Cascadia_302
PNW
2015 RubyRed GT M6 Premium
Had mine without a spring for a about a year and at first l liked it, but after awhile the pedal developed a bad judder (shaking/vibration) upon drive-off in first gear. Since l didn't want to go back to the stock spring l installed the Steeda spring and problem solved. To me the Steeda spring hits the sweet spot in feel between "no spring" and the "stock spring".:cheers:
MattW
Los Angeles area
17 LB GT w/ PP
I used vice grips to minimize the possibility of breaking the plastic end-pieces. Also, used the clutch petal depress tool:
metalhead79
That thang got a Hemi?
Colorado Springs, Co
2022 Mustang GT
I pushed the clutch all the way in and used a screw driver to pry it out. Was pretty simple.
I'm amazed at the difference in clutch feel now.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
I went for about 25,000 miles with no spring. No issues, but I didn't like that little bit of slop at the top of the pedal and I can launch more smoothly and consistently with the Steeda spring, and it's better for daily driving to boot.
LETHAL
From the D but in the NC
Asheville, NC
Kevin
2018 GT A10
I broke the brown spring perch when I did mine.
Had a hell of a time getting another. A kind soul here sent me one. Now Steeda sells the whole assembly if I am not mistaken.
tj@steeda
Timothy
Yes, we sell the entire assembly - much cheaper than buying the entire kit from a dealer.
Best Regards,
TJ
Crossroads
Coastal NC
2016 GT PP FRPP2
Same here. A flathead between clutch spring and the clutch pedal shaft and slide to the right.
Carfanatic
Cincinnati
Mustang
Make sure clutch is compressed when you slide it to the left. Less chance of breaking plastic perch.
