As titled I'm wanting to delete my resonators. I just don't want to hack up my exhaust and not like it. The car sounds great now, but,,,,,?
I'm coming from a 15 GT with the Xpipe and Roush axle back, that was loud.
FWIW, you can have some flanges put on the resonators and use pipe clamps if you really want to be cautious about it. I was going to go that route but that increases the cost several hundred dollars so I just took the plunge and had them welded in. I don't regret it at all. But I would say if you plan to go catless at any point, keep the resonators. Straight pipes (which is what exhaust valve open is) are just way to too ridiculous in volume and tone.
Definitely don't regret it...sounds amazing stock, removing the resonators is just that much better. The good thing is that in normal.mode there is no discernable difference, it sounds completely stock like it did before
It sounds good stock but does not give those pops and burbles that the R does. Mine are coming off on the 8th. My guy will cut them perfectly and I'll keep them just as I keep any stock part I replace.
