What is it about the 2018 mustang GT that gives it the sub 4 0-60?
NoVaGT
Northern Virginia
2019 PP1 GT Kona
I'm assuming that the DI/PI adds a lot of power all through the power curve, and that the HP number of 460 is misleading.
UAmach1
Bullitt Hopefull
PA
Ford/INFINITI
That's very possible. Do we even know if there have been head, cam or intake changes?
NoVaGT
Northern Virginia
2019 PP1 GT Kona
I've read that all of those things have changed, and the size of the motor's displacement.
wireeater
Virginia
wheelwell.com
Rich
Shadow Black 2019 Mustang GT Premium+ PP 6spd
Good tires + rear dampening are probably the biggest factor. 35hp doesn't = 5/tenths of a second.
phillybob232
Atlanta, GA
White Platinum 2017 GT/CS
Genxer
2015 Mustang GT / Perf pack / DIB
I was thinking along these lines too...about torque. That's one reason the Camaro is so quick, it's up 55 ft lbs on the current Mustang. The '18 makes up 20 ft lbs of that, and if it comes on down low even better.
Mazman
Sweden
2018 PP1 Mustang GT
Another + for the Camaro is the weight
Lucky13Cat
Overland Park KS
2023 Mach 1 Purple
I think it's all about the magneride actively going soft in the rear to allow the big weight transfer for way better traction otherwise it's just spin spin spin.:ford:
Conedodger
Ca
2017 GT350-R
I think the extra 500 rpm also help the car get to 60 faster.
Austinj427
CO
2017 GT350
The tq limiting is huge. AED was running some stellar times at the track with a car that didn't have any hp bump, just not allowing the car to limit itself and tranny tuning IIRC.
Dak2Zeke
Toronto
Tune a 15-17 for similar performance. Also most people on the streets would be lucky to do 4.4-4.7 in the 18.
w3rkn
Detroit
bmw 135is(sold)
Not this^.
The 2018 does 0 to 60 in under 4seconds because of the A10 tranny. The fact that it also comes with a brand new engine, with dual-injection and 460hp, only helps.
Previous Mustangs don't have an A10, so you are not going to get similar performance with adding HP. Not to mention, the 2018 is mechanically better machines.
sublimaze
2017 GT Premium
Obviously it is the new slats under the turn signals, feeding air directly to the tires
