UnhandledException
I m looking for wheels that are in the 20 lbs range. Any recommendations?
Can you tell me how much forged wheels are vs 6gr and the weight difference between the both?The reasonable price part is going to be the issue. The best bang for your buck is the 6gr wheels. If you want the lightest possible without carbon fiber you are looking at forglines and they will run you into the thousands. Next best is 6gr, but they are not forged (spun forged doesn't count). Either spend the money on billet forged wheels or compromise. I use the 6gr wheels for the street and have tracked them in the past. Many here track 6gr wheels. It's been discussed at length
I'd have to remove my DD 6gr wheels to weigh them. Probably not going to happen. However I plan to track the R in December and put the carbon fiber wheels on then. When I do, if be happy to put them on a scale.Can you tell me how much forged wheels are vs 6gr and the weight difference between the both?
I understand. My budget is $3000-4000. I could go higher but probably not worth it for a car that costs 60k in the first place. I feel that lighter wheels and CF drive shaft combined will make tremendous improvement.I'd have to remove my DD 6gr wheels to weigh them. Probably not going to happen. However I plan to track the R in December and put the carbon fiber wheels on then. When I do, if be happy to put them on a scale.
You are talking probably in the order near 5 grand for a set of forgelines (maybe less) (I'm sure someone will chime in). The 6gr wheels were less than 1.5 k IIRC. What are you trying to do?
The lighter you want the wheels, the more it will cost. How much do you want to spend?
It all really depends on the result you are after. Only you can answer that question (cost vs performance). I can say that it was a huge improvement on my track pack (when i had it) running lighter wheels and sticky tires. My advice would be forgelines and cup 2's. As your first mod (that is if you are building to track)I understand. My budget is $3000-4000. I could go higher but probably not worth it for a car that costs 60k in the first place. I feel that lighter wheels and CF drive shaft combined will make tremendous improvement.
Or pick 3 and pay ;)Inexpensive
Strong
Light
Pick two.
