veeefour
Troll
No, you are incorrect.I understand what you are saying by you would need to change the firing order to change when the over all valve event happens. You are incorrect thinking that by controlling lift you change firing order and valve event as you have defined as even BMW and nissan do not change firing order. Stop thinking of event as a whole and start thinking like everyone else who thinks of an event as being one of four things IVO, IVC, EVO, EVC and where they happen in relation to the crank. Lobe ramp rate, lift, separation angle, Ect. will make a lot more sense to you if you do.
The autos RPM limit is 6800 the manuals are 7000.
VCT is not that fast to change the valve timing for each single cylinder - it changes the timing for the whole event which is constant - and you can adjust the ignition hence you can change the timing.
My auto had 7000 limit - your info is wrong. I know - I looked inside my stock tune with HPT...like I said - I have one.
