Juben
- Jan 29, 2015
- Chattanooga, TN
- Justin
- 2015 EcoBoost Mustang (AT) w/PP
That's great advice. Like Mark said, just take your time and be VERY patient. It's easy and simple to do but you want to take great caution to ensure that you don't damage the turbine wheel. They're delicate, balanced pieces that need to be handled accordingly.Its very easy to change the turbine housing. Obviously 1st remove the turbo from the car and get it on the bench. There is one V Band style clamp that holds the turbine housing on.
Best thing to do is take the V band clamp off first, then hold the turbo and tap on the turbine housing gently to get it go move a little bit, like .010 to .020, just enough to open a gap for penetrating oil to get between the turbine housing and the CHRA, I like PB Blaster. If you cant get any gap at all, dont worry, just spray it and it will still soak in, just make sure the clamp is off so you can spray it all around. Be generous and let it soak for a while, even overnight, it does work, the longer it soaks in, the easier it will be to get the turbine housing off.
After its soaked a bit you can hold the turbo and tap on the turbine housing with a soft hammer, a brass hammer, or even a regular hammer if your careful, It will separate pretty easily if the oil has made its way between the 2 parts. If it dosent come off easily, take your time and use more penetrating oil, be patient, and let it sit a while longer. The key when separating the Turbine housing and the CHRA is to be patient and do it slowly, watch the gap start to open up and try to keep the same gap 360 degrees around between the CHRA and the housing. What your trying to do is let not the turbine housing hit the turbine wheel when removing it, and are be very very ginger with the removal. I can get them separated with no penetrating oil, but when they come apart easier, you have less chance of damaging the turbine wheel, so use the oil.
The Turbine housing on these Turbos have a pin to locate the rotation, so when you put your new one on, just locate the pin with your eyes and slowly and carefully mate the CHRA and the housing, by hand push the parts together or lightly tap together with a soft hammer. Put your clamp back on in its same location as it came off ( you could mark that or take a picture and look back at that ) do not over tighten that clamp, lube that nut as well. Spin your turbine wheel and look at the turbine wheel and compressor wheel while spinning to make sure all is well and your confident you did a good job.
The key to remember is that these turbine wheels are very thin and lightweight, so your going slow and being careful to try to not bend it. The more patient you are with the penetrating oil soaking and separating the 2 parts, the better off, its an easy job, just take your time, and always double check your work.
I use Kano Aerokroil (penetrating oil). It's the best stuff I've ever used and you could almost pull it apart with your hands after using it. Great stuff! You should check this stuff out too, Mark. Amazon reviews of Kroil
