2011-2014 Mustang GT 80mm TB How-to
zackmd1
Zack
Just got everything installed! The MPT tune worked perfectly with the 15+ TB! Could not get on it to much as it is wet and raining here but from what I was able to do the torque curve feels much flatter! This engine really came alive around 3k RPM with the stock TB. Now however power really comes on around 2k RPMs! So while I do not feel that I gained anything up top (wasn't expecting to) it has certainly effected the torque curve of the engine. Can't wait to try it out in dry weather!
fordguys550
yep..."just" a V6
tehachapi, ca
2016 v6 6spd
Thats good news man
D BERRY
LostAtSea
United States
David
2015 Mustang v6
Just saw one on EBay that is already to install. The guy drilled out the GT throttle body to the 3.7 size and used a 3.7 spacer with the center milled out to 80mm. I thought about this myself but wasn't sure if there was enough material to have enough left to seal a gasket. I also think he used a flat gasket. It's even got the bolts and coupler. " http://www.ebay.com/itm/2011-2014-M...80mm-Modified-Throttle-Body-Used/201784846149
fordguys550
yep..."just" a V6
tehachapi, ca
2016 v6 6spd
Hmm thats cool
Fuse
États-Unis d'Amérique
2016 Mustang V6
So if we wanted we could buy a GT spacer and just have it re-drilled. I'd imagined it'd only work with the '11-'14 GT TB.
[MENTION=6944]zackmd1[/MENTION] that sounds great. I've been waiting to hear the results from your updated tune.
Rika
guam
yellow 2016 v6 auto
Hello all,
So, let me get this straight. I have ordered the 11-14 gt throttle body. I also ordered the shapeway spacer/adapter. I also ordered the 4 inch 90 degree pipe and two 4 inch couplers. Is this whats needed? I know I have to get the clamps for the couplers. Anything I'm missing?
Thanks
Rika
whatdoyoufeedit?
whatdoyoufeedit?
Fayetteville, NC
2019 Race Red EB A10 (Formerly 2016 3X Yellow V6 M6), 1996 Mercury Cougar XR7 4.6L A4 (Future Coyote swap candidate)
Is it confirmed that the '15+ gt tb doesn't have enough material to move the holes 0.187" towards the center? I'm planning on buying a gt spacer and have both drilled.
This spacer in particular: http://www.ebay.com/itm/262412405696
It hasn't been confirmed or denied yet for the 15+ as far as drilling goes. It's just leaning towards the "might not work side" as it looks like there's much less material to work with.
Hello all,
Thanks
Rika
Sounds like you got your basis covered. :thumbsup:
MartinNoHo
Los Angeles
2015 Mustang V6 (2014-2020), 2018 Mustang GT Premium yellow (2020-XXXX)
Hey guys, i have ported intake manifolds on my car and i wanna know if a 14 gt TB will fit with the spacer linked in the first section will be basically bolt on like? and can someone clarify the shape of the pipe that's needed such has how long, and the degree for a stock factory box? I'm slowly, but surely going my way up to a custom turbo set up or SSM's stroker kit which was in the ginetta (if it can make 400ish BHP), might be that one, but I'm not sure.
zackmd1
Zack
I can confirm that it will not be possible to modify the 15+ TB. You would have to drill into the main body to get the correct spacing.
fordguys550
yep..."just" a V6
tehachapi, ca
2016 v6 6spd
i still cant believe I picked one up for 37 bucks lol
soldier989
Columbus OH
2017 GTPP Premium
Are there 90 degree intake pipes that have the PCV hook ups? I see a bunch of options on Amazon, but I'm not sure I want to delete the PCV tubes and do breathers quite yet.
fordguys550
yep..."just" a V6
tehachapi, ca
2016 v6 6spd
Its really not a huge deal...and very easy to change back to stock. Your not gunna find a proper pipe with the fittings on it
