Steeda Industry First - Adjustable S550 Rear Camber Mounts (Sneak Peek)
MtnBiker
San Antonio, TX
2015 Mustang GT PP
Thanks. I'm on the GT350R fronts so it lowered only ~0.7", and my rough guess is I've got about 1.5-1.7 deg in the front. Not sure what they'll be able to do without plates or bolts, if anything.
The Steeda Linear Sports lower just under an inch according to the spring rates & drops sticky. Seems about right. A little surprised how much travel it took to get those alignment numbers. I centered the struts by eye and you can see my starting point.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
If I can get them to within 1 tenth of a degree of each other and under -1.6, I'll be happy with that. The increase in front-end grip from a proper amount of camber is really nice, and it doesn't drastically increase wear unless it's over -2. Toe is the killer for wear.
MtnBiker
San Antonio, TX
2015 Mustang GT PP
I have some more driving to do before I want to take off the "understeer training wheels". Nothing but respect for these forum members who can drive the crap out of this chassis
BmacIL
Enginerd
Naperville, IL
I will say that with the wheel rates I'm at, and the current geometry settings, it drives closer to an FR-S/BRZ than a Mustang GT PP. The harder you push the smaller and more nimble it feels. It's remarkable.
Anyway, back on topic. Glad you got it sorted out after a brief scare!
tj@steeda
tj@steeda
Timothy
jasonstang
Omaha, NE
2017 GB GT/CS 6MT
That is pretty nice for small adjustments and locking everything in place. I like how it even has the nut side camber keyed so both would slide at the same time.
Now the question is will it have enough adjustments for say a car that's lowered more than 1 inch or it would be better to use the adjustable arms.
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
No problem for lowered S550's
Steeda Tech
tj@steeda
tj@steeda
Timothy
Here is a video for reference:
[ame="[MEDIA=youtube]rbkdyUt0TXI[/MEDIA]"]
TJ
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
Hello All:
I wanted to provide you with a sneak peek as to what we have been working on behind the scenes here at Steeda - Steeda's S550 Rear Camber Adjustment Kit (patent pending)!
Product attributes include:
  • Bolt-on Design
  • No Permanent Modifications
  • Allows for Simple, Easy Adjustment of Rear Camber Arms on ALL S550 Mustangs
  • Works with Stock Camber Arms, Steeda Adjustable Camber Arms & Aftermarket Non-Adjustable Camber Arms
  • High Quality Class 10.9 Bolts
  • Class-Exclusive Plated Steel Brackets and Bolts
  • Locking Hardware
  • Can be Installed without Removing the Rear Subframe
  • lifetime warranty!
  • Made In-House at Steeda - Right Here in the U.S.A.
Stay tuned for updates in this thread!
Best Regards,
TJ
Special thanks to Lund Racing for sharing.
This bracket also locks in the slide mount and re-enforces the inner IRS attachment point.
Well Jr remembered we had S550 rear camber arm brackets ! 555-4126 and these have lock plates !! So I am using these plates to lock that upper bolt in place and got the adjustable camber arms to fit ! It completely took ALL the fore and aft play out. I suspect when the car has wheelied in the past that the additional weight when the front is skyward was deflecting our other camber arm bushings. These plates also reinforce the OEM mount !!! I am excited !!!
