wildcatgoal
@sirboom_photography
Good point, and my experience supports that. Don't know if it proves it.As for cradles being off, the bad ones are pretty obvious. I also really believe that driveline vibration issues are caused and in some cases greatly amplified on some cars out there due to misaligned cradles from the factory.
My slight vibration over 80 MPH was eliminated after installing the alignment pins, even without a wheel alignment. Thought it was tire balance and I just ignored it because at the time I never much got over 70 mph and usually spent more time at 30 mph in traffic. I mean the vibrations can come from tons of places and my experience doesn't necessarily mean that aligning the IRS is the solution for all, but it helped me. Could very well have been that my simply unbolting and bolting in the IRS did something to solve it and the pins had nothing to do with it. I don't know... but I'll take it. I have no doubt the BMR lockout would have had the same "unexpected" benefit on my car.
To color this point, my cradle seemed to be out of alignment toward the driver's side such that when I put on 20" wheels with 315 tires, the driver side was flushed differently with the fender than the passenger side. The tire only rubbed on he driver side (which could be due to my weight but it was visually obvious. Pissed me off, actually. I never "checked alignment" (specifically camber between sides) to see if that was just the issue, though. Anyway, I went the Steeda route and the alignment pins fixed that entirely. BMR lockout would have done the same thing. Now my wheels/tires look the same on both sides under the fender.
Now if only there was a real solution to shutting up the noisy driveline, I'd be golden. #mt82andtorsenproblems
