pro 5.0
Whipple had suggested to machine the rear spacers down that sit between the idler plate and the water pump / timing cover, I see a 2 fold problem by doing that :
1) The belt is riding in the middle of the top 2 idlers and it's riding all the way back on the lower idler, if I move the entire bracket towards the engine the top 2 idlers will have the belt riding on the forward edge and the lower one will be in the middle.
2) The tensioner is mounted to the same mounting plate as the idlers and by machining the spacers between the idler plate and the water pump / timing cover the tensioner will force the belt back towards the engine and cause a misalignment of the belt.
3) I know they engineered the kit and perhaps there was no other way to mount the tensioner but IMO it would have been better to keep the idler plate as is and mount the tensioner on another bracket on it's own mounted off the timing cover. That way the variance in the stock casting would be decreased greatly as you'd be dealing with 1 point and not 5 like on the water pump / timing cover. The smooth idlers don't dictate where the belt rides so the variance there would have no bearing on belt alignment, the problem stems from the tensioner being mounted to the same plate that has the misalignment due to the variance in the water pump / timing cover. That would be eliminated if the tensioner was on it's own mounting surface.
