Ford Performance Suspension Parts Available At RPI Designs
Status
Not open for further replies.
RPI Designs
Salem, Ohio
www.rpidesigns.com
2015 Mustang GT - Test Mule
2015-2016-2017 Ford Mustang Ford Performance Track Strut and Shock Kit M-18000-F $675.00
Proudly Made in the USA
Fits 2015-2017 Mustang GT and 2.3L EcoBoost Coupes
Designed specifically as part of the M-FR3A-M8 Track Handling Pack
Designed for use with M-5300-Y Track Lowering Springs
Track tuned by Ford Performance Engineers
Kit Includes:
M-FR3A-M8 Track Front Dampers
M-FR3A-M8 Track Rear Shocks
Front Strut Top Mounts
Front Strut Spring Retainer
Front Damper Anti-Squeek Pads
Strut Rod Nuts
Threadlock
Note: When using Ford Performance Parts Track Lowering Springs M-5300-Y or any other aftermarket lowering springs it is recommended to use Ford Performance Parts Mustang Jounce Bumper Kit M-5570-B.
http://www.rpidesigns.com/shop/item.aspx/2015-2016-ford-mustang-track-strut-and-shock-kit-/
2015-2016-2017 Ford Mustang Ford Performance Track Handling Pack M-FR3A-M8 $1,299.00
Ford Performance Part's assembled Track Handling Pack is the perfect suspension system for the driver who demands the most from their car on the track or on the street. Kit includes pre-assembled struts, which do NOT require a spring compressor, and are ready to bolt-in! Put a little "road race" into your Mustang with Ford Performance Parts Track Handling Pack.
Fits: 2015-2017 Mustang GT and 2.3L EcoBoost Coupes
All components are designed to work together as a package
Lowers car approximately 1.0"
Gives a more aggressive-looking stance with a focus on handling and on track performance.
Will cause slightly harsher ride compared to stock springs
Track Handling Pack Includes:
Assembled Front Struts and rear shocks M-18000-F
Performance Pack Upper Strut Mounts M-18183-M
Sway Bar Kit M-5490-E
Performance Pack Rear Toe Links M-5972-M
Toe Link to knuckle Bearings M-5A460-M
http://www.rpidesigns.com/shop/item.aspx/2015-2016-ford-mustang-track-handling-pack-/
2015 2016 2017 Ford Mustang Ford Performance Street Sway Bar and Spring Kit M-5700-M $699.00
Fits 2015-2016 Mustang GT and 2.3L EcoBoost® Coupes
Kit includes: M-5490-E Mustang Track Sway Bar Kit and M-5300-X Mustang Street Lowering Springs
Lowers car approximately 1"
May cause a slightly harsher ride compared to stock springs
Gives a more aggressive-looking stance, as well as increased handling dynamics, yet maintains excellent ride quality
Highest quality manufacturing – produced by OEM spring supplier
Includes M-5570-B Jounce Bumpers and all Sway Bar mounting Hardware and Bushings
http://www.rpidesigns.com/shop/item.aspx/2015-2016-2017-ford-mustang-street-sway-bar-and-spring-kit/
2015 2016 2017 Ford Mustang Ford Performance Track Sway Bar Kit M-5490-E $479.00
Fits 2015-2016 Mustang GT and 2.3L EcoBoost Coupes
Sway bar kit designed for increased handling and performance
Best when used with the M-18000-F strut and shock kit and M-5300-Y springs
Includes all mounting hardware and bushings
Included in the M-FR3A-M8 Handling Pack
http://www.rpidesigns.com/shop/item.aspx/2015-2016-2017-ford-mustang-track-sway-bar-kit/
2015 2016 2017 Ford Mustang Ford Performance Track Lowering Springs M-5300-Y $299.00
Component of the M-FR3A-M8 Handling Pack
High quality manufacturing - produced by OEM spring supplier
Designed to work with the M-18000-F Strut and Shock kit and M-5490-E Track Sway Bar kit
For 1” lowering springs designed for stock struts, shocks and sway bars see M-5300-X
http://www.rpidesigns.com/shop/item.aspx/2015-2016-2017-ford-mustang-track-lowering-springs/
2015 2016 2017 Ford Mustang Ford Performance Street Lowering Springs M-5300-X $299.00
Fits 2015 Mustang GT and 2.3L EcoBoost Coupes
Designed to work with production struts, shocks and sway bars
Gives a more aggressive-looking stance, as well as increased handling dynamics yet maintains excellent ride quality
Highest quality manufacturing - produced by OEM spring supplier
Includes M-5570-B jounce bumpers
May cause slightly harsher ride compared to stock springs
http://www.rpidesigns.com/shop/item.aspx/2015-2016-2017-ford-mustang-street-lowering-springs/
2015 2016 2017 Ford Mustang Ford Performance Jounce Bumper and Hardware Kit M-5570-B $69.00
Fits 2015-2016 Mustang GT and 2.3L Ecoboost
Modified production jounce bumpers for lowered vehicles
Includes installation hardware
Included in the M-5300-X and M-5300-Y spring kits as well as M-FR3A-M8 And M-FR3A-MA Assembled Track Handling Pack
http://www.rpidesigns.com/shop/item.aspx/2015-2016-2017-ford-mustang-jounce-bumper-and-hardware/
RPI Designs
RPI Designs
Salem, Ohio
www.rpidesigns.com
dbegley
Minneapolis MN
Dennis
2017 Mustang GT Performance Package 401a
I have a 2017 GT with PP. As I understand the PP shares parts with both the Street and the Track packages from Ford. How about explaining what parts would be needed for either of these Ford suspension packages to upgrade to either from the PP. It is easy to think that if you have a PP car you need to replace all the parts when in fact that is not the case. For example the PP package is the Street package except for the springs.
Actually it would be nice to have a "package buy" for PP cars with only the parts that are really needed to upgrade.
thanks
RPI Designs
RPI Designs
Salem, Ohio
www.rpidesigns.com
thanks
I will do some research and see if I can figure this out.
RPI Designs
RPI Designs
Salem, Ohio
www.rpidesigns.com
Okay here is what I found and I could be wrong because I did my research on the internet.
The struts, springs, and sway bars, bushings etc. are different than what is factory installed on PP cars.
The Street Package is closest to the factory PP parts but they would still be an upgrade overt he factory parts. The springs are 1" lowering springs and are firmer than the stock springs. The struts have firmer valving in them and the sway bars are a little larger. The street package is great for a daily driver as you will see and feel a improvement but your ride will not be uncomfortable.
The Race Package is a step or two above the street package. The springs are made out of a larger diameter wire than the street package the struts are firmer and the swaybars take another step up in diameter. This setup may be to firm for most people and will really transmit road vibrations and impacts to the passenger compartment.
So any suspension part you want to change would be more performance oriented than the factory parts you would be removing. It is just up to you as to how firm you want your suspension to be.
Zissou
Charlottesville
2016 GT/CS
What's your take on the FRPP Track Package for aggressive street driving / daily driving / realistically not seeing the track more than once per year?
Coming from a Fiesta ST with Mountune springs - would like no rougher ride than that and ideally less bouncy.
Basically how do I make my car handle like a GT350 (or 80% of the way there)? That car had the most perfect set up for balancing comfort and handling for me.
RPI Designs
RPI Designs
Salem, Ohio
www.rpidesigns.com
If you have terrible roads like we do here the race springs may be too much for daily driving. The best compromise would be the street springs and race struts and sway bars. Any rubber bushings you can replace with urethane and a sticky set of dedicated summer high-performance tires will get you where you want to be.
Zissou
Charlottesville
2016 GT/CS
Good to know. Our roads are actually quite good here, though out in the country they can get bumpy. Very little potholes though. The worst road conditions we have are bridge expansion joints and that coarse pavement surface they do out on some country roads
Status
