Mine rubs metal on metal. Part of the paint is scratched!!Is it metal rubbing on metal? I noticed my passenger side door is rubbing on a soft/foam insert in the door well near the glove box.
Glad to hear they got it all taken care of, mustangirl! Let Nick or I know if you have any future questions or concerns; we're here to help.FYI, turns out my hood, front left fender, AND passenger door were slightly misaligned enough to cause wind noise. I should be getting it back today.
Take yours in to Ford, they will send it to a body shop (or they will let you take it there yourself).
I had metal on metal rubbing. Ford sent my car to a body shop where they adjusted the driver door, left fender, and hood.I just discovered the same foam/insulation rubbing problem on passenger door. Glad it wasn't metal on metal. I pushed the foam back until it didn't rub. Then noticed only the top of the foam piece had a plastic nut that was in its holder while the bottom was missing. Did you notice the same and how did you get yours fixed?
I will look at the hood this afternoon, as I am still experiencing a little bit of wind noise. Thanks!I had the same wind noise and passenger door rubbing the foam problem! The rubbing didnt bother me and the wind noise was a whistle and i fixed it by adjusting the plastic hood stoppers! The hood is lower now and wind noise is gone, i think the problem was the vents on the hood was high enough to direct the wind towards my windows cause it was coming right by the window area, i lowered the windows and still was able to hear it! If you guys have that wind noise problem try adjusting the hood more downward!
I had this... my fix was to bend the passenger side rubber window gusset inwards (i.e., towards the window) to form a tighter seal to the window. Used fingers, no tools. Greatly reduced the noise.Anyone else getting wind noise when driving above 65MPH on the freeway? Specifically, front passenger side door/window area?
Starting to get annoying.
I still have not been able to fix my issue :(. No matter what I do the noise is always still there. It sounds like there is wind or air moving through the passenger side door area. Its not a whistle like traditional wind noise. But wind moving through the passenger side door where the vents/ speaker is. Has anyone heard this same noise above 60MPH?
I swear its the wind being drawn from the hood or engine bar area traveling along or inside the passenger door area. HELP please! I took it to Ford and they said it is the turbo. re-circulation which is complete BS, because I know exactly how that should sound.
