Magnaflow Stainless Steel Tru-X Resonated X-Pipe for all 2015-2017 GT Mustangs
Status
Not open for further replies.
CJ Pony Parts
Harrisburg, PA
www.cjponyparts.com
A large variety of Mustangs across all generations
EXCLUSIVE TO CJ PONY PARTS and IN STOCK!!!
Magnaflow Clamp-In Stainless Steel Tru-X Resonated X-Pipe for all 2015, 2016 and 2017 GT Mustangs.
CJ Pony Parts has an exclusive part for your 2015-2017 GT Mustang, the Magnaflow 1004384 Clamp-In Stainless Steel Tru-X Resonated X-Pipe is only available right here!
If you are running long tube headers, muffler deletes or an aggressive axle-back, this Clamp-In Stainless Steel Tru-X Resonated X-Pipe from Magnaflow is for you. Deleting your factory resonator will add potentially unwanted gains to your volume and raspiness. The only option to avoid that unwanted noise was to pay an exhaust shop to fabricate and weld up something that was not a modular solution, but not anymore. Now you can achieve that x-pipe sound, increase flow, maintain a deep tone and not add additional raspiness with Magnaflow's Clamp-In Stainless Steel Tru-X Resonated X-Pipe.
This exclusive Clamp-In Stainless Steel Tru-X Resonated X-Pipe from Magnaflow is constructed of 100% 409 stainless steel. To deliver a smooth, deep tone, stainless mesh wrap and acoustical fiber fill are utilized. In an effort to ensure that smooth, deep tone you are looking for does not diminish over time this X-Pipe is packed to the gills with acoustic fiber fill. The dual intakes measure in at 2-1/4 inches and the corresponding outputs measure in at 2-1/2 inches to maintain the free-flow straight-through the perforated stainless steel core.
Features and Benefits:
- Free-flowing, straight-through perforated stainless steel core
- Stainless mesh wrap and acoustical fiber fill to deliver a smooth, deep tone
- Packed tight with acoustic material to ensure long life and no sound degradation over time
- 100% 409 stainless steel construction
- Dual 2-1/4" in and 2-1/2" out design
- Cut and clamp installation
- No welding required
- Includes necessary clamps
- Weighs 14.7 lbs. (Compared to most resonator deletes weighing in around 9-10 lbs. and the factory resonator weigh approximately 23-24 lbs.)
- Made in the USA
[ame="[MEDIA=youtube]CwvUbi0bHnQ[/MEDIA]"]
If you have already paired a resonator delete with your long tube headers, muffler deletes or aggressive axle-backs and you want to tame it down a bit without sacrificing that deep tone this exclusive, resonated X-Pipe is your solution. Don't reinstall your factory resonator or have an exhaust shop weld something up when this new X-Pipe will solve your problem without breaking the bank or undoing your performance upgrades.
Designed and engineered to share the same mounting locations and dimensions of the most popular and largest resonator delete, this Magnaflow 1004384 Clamp-In Stainless Steel Tru-X Resonated X-Pipe is a direct swap for anyone that already has that resonator delete installed. If your current resonator delete in not an exact swap for this exclusive X-pipe a simple trim off of your existing tailpipe will give you all the room you need to complete the clamp-in installation. This cut and clamp installation requires no welding and this exclusive X-pipe comes with the required clamps.
Please Note: Installation requires cutting of the factory exhaust piping. Once the modifications have been made to the factory exhaust system, Installation is a simple bolt-in procedure using the included clamps.
*Fits all 2015-2017 Mustang GT Fastbacks and Convertibles.
*This part is exclusive to CJ Pony Parts.
Order this Magnaflow 1004384 Clamp-In Stainless Steel Tru-X Resonated X-Pipe for your 2015, 2016 or 2017 GT Mustang today from CJ Pony Parts.
The original thread can be found HERE and contains a lot of great information and additional sound clips.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Excellent choice for a little bit more volume than the stock resonator, but a much improved tone! It does take a couple hundred miles to fully break in.
bodam
Houston, TX
2015 GT Premium Auto
I wonder how this one compares to the Borla one
CJ Pony Parts
CJ Pony Parts
Harrisburg, PA
www.cjponyparts.com
Check out the link at the end of the post to the original thread. What you are saying has been done and the results are night and day better in my opinion.
BmacIL
Enginerd
Naperville, IL
Just a bit louder and you get the X-pipe tone vs. the H-pipe of the Borla. It's still a lot quieter than a resonator delete X or H.
Status
