Armen
Hi everyone,
Just thought I'd start a thread on here about an issue I'm having. The car is at the dealership and has been since Tuesday May 16th.
The motor is stock right down to the OEM air filter. There is no tune and never has been.
I had the oil, transmission, rear dif and brake fluid changed at the dealer May 8th and then a lapping day at a local short road course on May 11th. The car performed well at this event. On Sunday May 14th I noticed a rough idle on start up. It only lasts for about 10 seconds and then the engine runs normally and there are no driveability issues.
On Monday May 15th, same rough idle at start up only this time the CEL came on. The engine again smoothed out after about 5-10 seconds and drove fine. My OBDII reader said P0300 - random misfire. Unfortunately this code isn't very specific and no other more specific code registered.
Took the car into the dealership Tuesday May 16th and advised them of what was going on. They've had the car since that time. When I last checked in, they said they acknowledge the rough idle and P0300 code but that they can't determine the cause at this point.
They are in communication with Ford Technical Support to determine the issue. I'm rather surprised it's such a mystery considering the motor/drivetrain are all stock, however, I will wait for their diagnosis.
I will update when more information becomes available just in case others will experience this problem.
