Modifying As-Built Data Guide
stang1971
kcmo
2018 Premium Plus Magnetic GT
I'm not sure why everyone focuses on the bluetooth adapter unless you really need wireless or if you want to be able to view things on an android phone. The bluetooth adapter is much more expensive and nothing will be more reliable than a wired solution.
I bought an ELM eBay special a month or 2 ago and posted about it in this thread. It's USB with the switch on it. It was very inexpensive, I think around $11. I put the link and sales info in this thread. I get 23 modules and it has worked flawlessly for me.
I have an iPhone so the bluetooth adapter wasn't going to help me and the wireless adapter has gotten terrible reviews so for me it was an easy call. I have a Kiwi3 adapter I use on my iPhone but it doesn't work with FORScan (yet).
link of said adapter? ty
jbailer
Joe
stang1971
kcmo
papinist
The Italian Pony
Tuscany, Italy
Stefano
Mustang EcoBoost MT Race Red EURO - NO MORE
Hi everyone.
I created this spreadsheet so we can keep track of this information. I'll be populating it on the coming days. Please let me know if you got something to add.
As-Built Values Spreadsheet
Thanks! Other than the values you can find on the original spreadsheet linked in first post, there are many info scattered on the entire thread.. if\when I have time, I'll try to collect some.
Retroflect
NA
2015 Ecoboost
I've just gone through all pages tonight and here some of the misc ones I found from others posting:
Police Dark Mode:
Code: 726-32-01: 0A01 0000 006B
Change to: 726-32-01: 0A01 0100 006C
Double Horn Honk Reminder (Engine on, Keyfob not in car):
Code: 726-41-02 0001 0001 0072 - Enabled
Change To: 726-41-02 0000 0001 0071 - Disabled
7D0-01-02 x2xx xxxx xxxx enabled
7D0-01-02 x0xx xxxx xxxx disabled (Home Screen showing Compass)
(I've also seen people say to change this to a 4 so I'm unsure on this one)
Disable Door Ajar Chimes
IPC 720-01-02 xx0x xxxx
disable the sound symposer
If it is a fake ACM generated one...
(ACM)
727-01-01 xxxx xXxx xxxx
Change that value at X... it is probably currently an A or 2 (or whatever value). Subtract 2 from it... If it is an A make it a 8, if it is an 2 make it a 0, etc...
Simultaneous High Beams and Fog Lights location
Code: 726-27-01: 0100 0001 0058 (Disabled)
Change to: 726-27-01: 0100 0000 0057 (Enabled)
PAM (Parking Aid Module)
736-01-01 XXXX XXXB XX
Retroflect
NA
2015 Ecoboost
papinist
The Italian Pony
Tuscany, Italy
Stefano
I remember there is a code to enable honk when doble press lock button..?
jbailer
Joe
I have a copy of the original spreadsheet that I downloaded and have been adding a bunch of things to it. If you PM me an email address I'll send it to you.
It has:
Door Ajar Chimes
Door Ajar Chimes
Rear Axle Ratio (XXXX = ratio in hex)
Rear Axle Ratio (3.15)
Rear Axle Ratio (3.31)
Rear Axle Ratio (3.55)
Rear Axle Ratio (3.73)
Rear Axle Ratio (4.10)
Simultaneous High Beams & Fog Lights
Turn Signal Hyperflash
Simultaneous Fog Lights & Turn Signal
Police Dark Mode
Police Dark Mode
12v Powerpoint Timeout (Default)
12v Powerpoint Timeout (Immediate Timeout)
Double Honk Reminder (Engine On, No Keyfob)
Secure Idle (automatic)
Sound Symposer (Ecoboost)
MyColor Power & Support
MyColor Power & Support (hardware required)
Soft Climate Buttons (On Touchscreen)
Soft Climate Buttons (Seat Cooling only)
Soft Climate Buttons (Seat Cooling & Heating)
Soft Climate Buttons (Seat Heating only)
Sync/MFT Startup Animation (Ford)
Sync/MFT Startup Animation (Black Label)
Sync/MFT Startup Animation (Raptor SVT)
Sync/MFT Startup Animation (Mustang Pony)
Sync/MFT Startup Animation (Mustang Pony, GT)
Sync/MFT Startup Animation (GT350 Snake, Gray)
Sync/MFT Startup Animation (Vignale)
Sync/MFT Startup Animation (GT350R Snake, Red)
X0AYHAM0X
United Arab Emirates
Mustang 2015 V6
Oh no! I was going to pull my resistors out and do this. I wonder why it didn't work? I went through a lot of effort to get them wired in there. I'd hate to pull them out and find out it doesn't work.
This worked now!
It was actually the 2nd bit needed changing:
27-01: X*XX XXXX XXXX
Mine was 1 so I changed it 0 and it worked!
Normal blinking feels awkward to me as I got used to the dancing tok tok tok lol
jsn1
California
2017 Mustang GT PP
This worked now!
Great news! It has been added to our list.
jbailer
Joe
What's turn signal hyperflash?
If your turn signal goes out, it will blink fast and at an odd rate inside the car to warn you a bulb is out. Also, if you replace the regular bulbs with LEDs, the circuit thinks the bulb is out and will do this. For those of us that switched to LED turn signals, this is nice to avoid the annoying sound.
